Natalie13
Jun 30, 2022 8:42 PM UTC
Assets don't export as is when a "layer effect" is applied
When we’re exporting our asset that have any layer effects applied - such as “multiply” or “passthrough”; the exported asset/image looks different.
Any way to export assets as they show up in Figma with the applied layer effects?
I have two cases below - each one using a different layer effect, but same problem where the exported asset doesn’t have the effect applied anymore
Any help would be much appreciated!
Nikolaj
Feb 7, 2024 11:06 AM UTC
Yep! Would love an answer to this!
Thank you ❤️
Feb 8, 2024 5:22 AM UTC
Hi @Natalie13 @Nikolaj,
Thanks for reaching out. Have you tried “ignore overlapping layers” when exporting before? If no, could you try along this help center article?
If the issue stile persists, the exporting issue could be tricky. So, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new
Toku
