Animation glitch
Fede_Mondino
Does anybody know why am I getting a glitchy animation when I try to make an expandible menu? Like an accordion dropdown. When I want to animate a frame or a rectangle from the size A to size B, it works but with a visual glitch, and it’s more noticeable when using rounded corners.
I made a basic animation, click the small rectangle, it expands, click again, it goes to the start size… there are 2 versions, one of them with rounded corners, one without them. Here is a screenshot of the glich when I play the animation. I would love to post a video but I can’t do that yet (I’m pretty new to the forums).
I already have a solution to make the animation work like I want, but it’s more complicated in terms of structure of the component, and I really want to know if this is a bug or if I’m doing something wrong.
Thank you all!
Best answer by Celine_D
Hey everyone, sorry for the late reply.
Don’t worry ​@Fede_Mondino , thanks for reaching out to our support team!
I’ve checked internally, I can confirm that we were able to reproduce the issue.
To give you more visibility here, our engineering team has conducted a comprehensive investigation and confirmed that the problem you're facing is indeed related to a new bug. At this time, we do not have an estimated timeline for a resolution.
I understand that this is not an ideal solution, but please know that we are actively working on improving our platform and addressing issues like this. We appreciate your understanding and patience as we strive to provide a better experience for our users. Thank you!
Luke-Itineris
  • Active Member
  • 128 replies
  • October 7, 2024
Can you share a proto link so we can see for ourselves?
Fede_Mondino
  • October 7, 2024
Sure! Here is the URL: https://figmashort.link/32Zbj2
Luke-Itineris
  • Active Member
  • 128 replies
  • October 8, 2024
Thanks. Try changing the rectangle shape, to a frame with border radius. See if that helps the transition.
Haroll
  • Active Member
  • 273 replies
  • October 8, 2024
Hi @Fede_Mondino
Looks like a bug to me that should be reported to Figma : Figma : Submit bug report
I replicate your issue, and it appears the animation become glitchy when a stroke is applied to an element. Without it everything worked as expected.
(Tested with Frame, Auto-layout Frame and Rectangle — same result each time)
stroke-bug
Fede_Mondino
  • October 8, 2024
Thanks Luke, but as I said at the beggining of the post, I tried with both frames and rectangles and it didn’t work 😓
Thank you Haroll! I’m going to report it!
Celine_D
  • 3381 replies
  • October 17, 2024
Hey @Fede_Mondino , thanks for flagging it!
Anju, our technical quality specialist is waiting for your response for further investigation. Please check your inbox via mail (for your reference, your ticket number is 1143725), thank you!
Deko22
  • December 16, 2024
Same thing for me… I was wondered if it applies to auto-layout only, but this issue reproduces even for the pure rectangle. Here, it works fine for enlarging, but has the glitch when clicked and shrinks back: https://www.figma.com/design/2dnmDI3dBAmZpKax3RgXU6/Untitled?node-id=1-2&t=99qRYQ1CG5t7CK3m-1
Fede_Mondino
  • December 17, 2024
Hi Celine, yes I received the email from Anju, but she was asking me to make or send things that I had already made or sent, so I never responded again.
I didn’t want to waste any more time on that issue, I just wanted to let you know about the glitch so you could review it, but it’s not something that prevents me from doing my job and that’s why I didn’t give it much importance.
It’s easy to reproduce the glitch, as you can see, Haroll did it and left a gif in this same topic, I hope you can fix it very soon.
PS: Just in case, I never wanted to sound rude, I’m not a native English speaker and I don’t know if the expressions I used were the correct ones to communicate what I needed. Sorry in advance if that was the case, and thank you for your interest in helping me!
Seth Akkerman
Hello hello!
@Celine_D and ​@Fede_Mondino Did either of you find a solve for this? I have the exact same issue in my file.
Celine_D
  • 3381 replies
  • February 3, 2025
Cody_Thompson
One of the designers I work with just ran into this issue as well.
