Adding 1px when it's exported
  • February 14, 2023
  • 19 replies
  • 4610 views
sometimes, I see the situation like image added with 1px when it’s exported
is there any solution for these kind of things?
Justin_Dilbeck
June 7, 2024
Same I get 1px borders added on exports. sometime with sometimes without I cannot figure out why seems like a bug
Josh
Former Community Manager
June 7, 2024
Hey there! Are any of the layers on sub pixels by chance? this is the most common reason for an export to add a pixel to the width/height.
Darius_artepress.media
June 7, 2024
@Justin_Dilbeck try this. First, make sure the dimensions and XY positions of each frame are whole numbers or decimals. If they have decimals, select the frames you want to export, change the dimensions to whole numbers, and in the top menu, choose Arrange —> Round to Pixel. This usually helps. Also, make sure the frames have the Clip content option checked. Good luck!
Dennis_N
Power Member
July 17, 2024
Yes, but c’mon this really should not increase the dimensions for exported assets out of the blue. Figma should be able to handle this case as it simply is unexpected behavior.
I hope that this already is in your backlog. People will keep stumbling over it again and again. Thanks
Julie_Turcotte
July 31, 2024
You saved me hours of frustration. Thank you
Matt46
October 23, 2024
Praise be to artepress ! This has been bugging me for days, and chalked it up to the latest update. Thank you !
Trev
THANK YOU!
I’m embarrassed for Figma that this is an issue. My engineer just questioned my ability to export squares. Now here I am with a ridiculous but believable answer AND solution.
Ryan_Rizzio
Has anyone here noticed it’s been fixed or is this still happening?
I had this too back then and the solve for it outlined here is tedious and time consuming, especially with 50+ ads/mock frames in some projects.
The process for delivering files is makes it even worse when I need to export them because drag files into a compressor, then upload them and enter project details and tags to our DAM, add them to a sharelink, and then prep a handoff message and complete the ticket only to come back a day or two later and need to do it all again because of some silly issue.
Figma is incredible in so many ways so I can’t be too frustrated, but hopefully this gets fixed soon because it’s a really frustrating bug.
Shauna_Lynn_Panczyszyn
I’m dealing with this now and every solution presented isn’t working. I have a frame that is 750 and it’s exporting at 751.
Sarah_Shuda
This has been a frustrating bug. In Dev Mode, the arrange > round to pixel option isn’t available. How do we solve this without access to Design Mode?
