Why when I import SVG, it turns into an image not a vector?
Nicole_Veigas
When I import an SVG from Photoshop into Figma (either by dragging it into Figma or “place image”), it doesn’t import as a vector it becomes an image. I want the SVG to be a vector. Is this happening because I’m saving it incorrectly in Photoshop or because I am importing it incorrectly?
Best answer by Gleb
You are probably saving a raster image embedded into the SVG format.
  • May 5, 2021
Nicole_Veigas
okay, thank you!
Kate_Aid
Could you please explain the raster problem further? Does the color format matter? I am having the same issue (SVG files appear in Figma as an image within a frame, not as a vector) with SVGs from multiple sources.
  • July 27, 2022
SVG is a container format that may contain multiple things:
  • Vector paths
  • Vector shapes
  • Text
  • Raster images
If you save a raster image (like a photo from Photoshop for example) as SVG, it doesn’t automatically become a vector image. It simply becomes a raster image contained within the SVG file. Thus upon importing into Figma, it simply becomes what it is: a raster image in a frame.
Kate_Aid
Thank you, @Gleb! That’s the clearest explanation I’ve had and exactly fits what I’m seeing. I’m working with a flat logo image, but it did come to me as a PNG, so I’m now exploring if there are other ways Photoshop can convert/vectorize it into a true SVG.
  • July 27, 2022
This can be done in Illustrator or in Figma itself with the help of plugins. Search for “trace” or “vectorize” and you will find lots of options.
Kate_Aid
I don’t have Illustrator, so it’s great to know this can be done in Figma. Thank you again for your help!
