WEBHOOK :: LIBRARY_PUBLISH not working
OleZha
Hello everyone!
I have a problem with Library_publish.
Whebhook doesn’t send a payload when I was modified library file (for ex. styles) and pressed a button “publish”. This method just working when I publishing a new library, but I need it for existing library.
Other method FILE_UPDATE working normal, but I need a trigger when library updated and published and not for each change of file.
How can I fix that? Thanks.
Best answer by OleZha
Solved via FILE_VERSION_UPDATE, and parse “label” => “Components Published” 😆
OleZha
  • June 15, 2021
David_Villarroel_Escorza
Does anyone tell or post the link to do the “FILE_VERSION_UPDATE” manually? PLS.
After last update a lot of bugs has appears and it turn annoying during daily work. Thanks and regards.
