Text Styles in Figma
sunil.akula
Hello Guys - Need your suggestions and inputs
Designed an application in Figma and everywhere regular designed with 16px
Now I need to change the font size to 14px as the base font size.
It is very easy if you define a “Text Style” in Figma. But what will be the workaround for two scenarios
  1. “Text Style” is not defined and is not applied everywhere.
  2. “Text Style” is defined, but not applied everywhere, because of duplicating the elements, copy paste job
Best answer by Gleb
You can select objects with similar properties using Edit → Select all with same text properties or use the plugin Select Similar to control the selection better. Then apply a text style to them.
  • 4707 replies
  • August 21, 2021
  • September 20, 2021
