Testing library updates before publishing
  • November 10, 2022
  • 5 replies
  • 740 views
Rockytori
Hello!
Does anyone know if there’s a way for me to test the impact of the changes I’ve made in the library before publishing it? There were a couple of times I’ve noticed that the updates I made reset the content (my fault for restructuring layers, renaming them, etc). But now I’ve got PTSD and I just really need to make sure that when designers get the update, nothing gets broken.
Thanks!
Best answer by Pavel_Kiselev
Hey
Publish pre-release version and try it on a file. You can swap libraries to see how it would work. Don’t forget to back up test file though )
Pavel_Kiselev
  • 438 replies
  • November 11, 2022
You can make exact copy of the file you about to publish, I would name something like “Pre-Releas Test Build”. Work with the new copy, but does not hold swapped we need to quickly now you can test your designs
Jeppe_Boutrup_Nielsen
Hi Pavel,
So how would you test if your “Pre-Release Test Build” breaks anything in a consuming team’s main design file?
Pavel_Kiselev
  • 438 replies
  • November 22, 2022
Hey
Thanks for the quick clarification! I’ll try that out 🙂
Pedro_Batista
but swap libraries doesnt seem reliable on a component with variants specially with colors
