Set background image location
Mason_Cook1
When I set the fill of a frame/shape to an image, it would be really good if i could set the image to fit, and then choose where to place it in the frame (top, bottom, left, right).
xMOx
  • Active Member
  • May 17, 2022
Yeah like in web you can set your image as Fill and then select which corner you would like the image to scale/expand from. Yes, this will make things much easier. I know you can use the Crop method but after you crop your image if you decided to scale your image from one side it will stretch/distort the image which is not helpful, so if I use the Crop method I can only scale with proportions Or scale up and then adjust my crop. You’ve got my upvote my friend 👍
  • August 15, 2022
