How to make a flexible width component consisting of text and an element as a stylized "underline"
  • July 22, 2022
  • 1870 views
Rory77
I’ve got this heading style component. I’d like to be able to use this component in designs and type in proper placeholder text and have that stylized underline element with the jagged edge you see to match the width of whatever is typed.
If the text happens to break to 2+ lines, the stylized underline should remain under the “block” of text but still stretch the width of the text responsively, not repeat per-line of text as it would if you were just using like for example.
I feel like this has probably been asked, I’ve searched but it could be I’m just not searching against the correct terms. I’m coming from Adobe XD so things are just different enough to throw me off.
Apologies if this is a repeat.
Thanks for your suggestions.
Avokadomos
  • Active Member
  • 377 replies
  • August 15, 2022
Make the wrapper into a vertical auto layout frame, and then set the underline to fill container and use a tiled image.
