How do I override placeholder images in interactive components/variants?
Osagie_Eigbe
Hi, I have a component that is basically an image card (a frame with the background fill set to Image, with a default image) with some text on it, now I’ve created a variant (Hover State) that is just meant to have a darker background so the text is more readable.
I have prototyped it to Change To the hover state when you hover over the main component.
For the component instance, I have changed both the default state and the hover state to a new image.
When testing, this doesn’t work as it still shows the placeholder image for the hover state.
How do I fix this?
I have also tried using a rectangle for the image fill instead of a frame, but it still doesn’t work.
I have also tried not adding any image to the main components, still doesn’t work (For this I tried leaving the default Figma black/white checkered boxes as well as just leaving it as a solid fill.)
I’d appreciate any help. Thank you.
Here’s a link to the file: Figma
Best answer by tank666
Hi @Osagie_Eigbe, I created a base component that only uses a gradient, and then I created a component set based on this base component in which to insert an image. You can test the functionality of the component in your source file.
tank666
  • 4873 replies
  • January 13, 2022
Osagie_Eigbe
Checking it now. Thank you!
Osagie_Eigbe
Tested and recreated. It works. Thank you!
jhonalbert
The variants section of your tailwind.config.js file is where you control which variants should be enabled for each core plugin:
// tailwind.config.js
module.exports = {
variants: {
extend: {
backgroundColor: [‘active’],
borderColor: [‘focus-visible’, ‘first’],
textColor: [‘visited’],
Danee_Avery
I have the same question, and I see there’s no answer yet. I’m hoping there is some way to apply the image override to all variants.
Mojo
  • 67 replies
  • February 11, 2022
That’s an expected behavior, you are changing the image on the first component and when it gets replaced with the hover one, there’s no image. Try creating a master component. One component that then you duplicate, wrap it as a new component and with that you have 1 of the variants. Do the same for the hover, and with both instances create the variant.
Now when you replace the image is getting replaced on the same component.
Danee_Avery
I thought that would work…
You can see hereI have the default component nested inside the hover component. But when I combine as variants, the default style isn’t honored—it switches to just “media block”.
https://share.getcloudapp.com/kpu4vjby
https://share.getcloudapp.com/d5uNjKP2
What am I missing?
tank666
  • 4873 replies
  • February 11, 2022
Hi @Danee_Avery, check out the file i edited for the topicstarter:
Figma – 13 Jan 22
Danee_Avery
So the image is added to the instance, not the variants. Makes perfect sense—thanks!!
  • March 13, 2022
