How can I un-component a component?
Tim_Hacker
i feel like i am going insane but i cannot find the solution to this. once i create a component i cannot undo this. i can only detach instances of a component
i already uninstalled all plugins and reproduced it in a new file. am i missing somthing glaring obvious?
Best answer by tank666
Yes exactly.
https://help.figma.com/hc/en-us/articles/360038665754-Detach-an-instance-from-the-component#Keyboard_shortcuts
  • 4710 replies
  • May 30, 2021
Detach instance and delete the component.
Tim_Hacker
  • 9 replies
  • May 30, 2021
so you are saying it is not possible to convert a component back?
tank666
  • 4873 replies
  • May 30, 2021
Tim_Hacker
  • 9 replies
  • May 31, 2021
I know how to detatch an instance. I wrote that in my first statement.
A_K
  • June 2, 2021
I feel your pain. This is such a simple function and yet they make it so amazingly complicated. I find the same nonsense with adding a simple border to an object. They have 400 ways to shade the color of a box, but not even 1 simple option for drawing a line around the box. I get the feeling the Figma designers don’t ever use their product.
Tim_Hacker
  • 9 replies
  • June 2, 2021
I get it, I miss these options as well. I dont think they use it at all though.
Tingting_Cheng
There’s a plugin called Detach Master, if that’s what you mean?
Eliane_Salles
Thank you so much.
Paul_Roberto
Make a copy, detach it from the original, delete the original.
Rafaela_Dantas
WOOOOOOWW! Thank yooou! <3
Julia18
  • October 11, 2021
You are Goddess!!
Andi_Gigatera_Halil_M
Thanksss thankss lot of thankssssssssss
Iva_Mance
  • November 5, 2021
Thank you very much! 🙂
Philipp_Binggeli
That’s a little bit insane. You can un-group a Group, anytime, but you cannot un-componentize a Component after it has existed for a while?
Andrew_Kim
This is so stupid. Please make it an option in right click to undo a main component and revert it into a group or whatever it was previous to becoming a main component!
Andrew_Kim
i wholeheartedly agree… i was stuck on this for a bit
Sebastian_Garzon
In so much time i don’t felt this happiness
Chris_Nelson
This is how I fixed it! Thanks!
MARK_RIVERA
Thank you for this.
business_ocean
I am using this Trick. Duplicate component deattach it and then delete main components
Sammy_Guergachi
Please add a way to de-componentify a component! This is kills flow so hard!
Momodu_Oladapo
Create an instance by duplicating then delete the master component after then detach the duplicated instance and you’re good to go.
