Height auto for image at components
  • October 5, 2022
  • 1176 views
Stefan
  • 10 replies
I often run into the problem that I would like to have the following properties for an image in a component:
width: 100%
height: auto
This would be good if images have different aspect ratios to be able to place them anyway. Currently I can’t make a component out of it, because I can only replace the fill here and then the height always remains the same as defined in the component.
Best answer by djv
Hey @Stefan,
It sounds like you’re wanting to use Scale/Scale constraints for your image within your frame, before creating a component out of it.
Stefan
  • 10 replies
  • November 6, 2023
This is probably a common scenario, isn’t it? How do you solve the problem?
  • 4852 replies
  • November 7, 2023
Hey @Stefan,
Stefan
  • 10 replies
  • November 9, 2023
Thanks for your reply! Not sure if this helps if I wound width: 100% height: auto scenario within my component? So height of image jumps depending on native image height.
