Figma app Installation has failed (Windows)
Artur_Kukharski
Hello, I have a problem with the desktop version Figma. Before I work and after the last update, Figma didn’t open more. When I try to install a new version it gives allert.
There was an error while installing the application. Check the setup log for more information and contact the author.
On the file I see alert like
System.IO.FileNotFoundException: Could not find file C:\Users***\AppData\Local\Figma\app-98.14.0\resources\app.asar.unpacked_codesign’
When I go to this route windows said he can’t find this file too. But if I go there step by step I see the file.
Best answer by Artur_Kukharski
Ok. I find how to fix this problem.
  1. Nedd open soft “command prompt” like administrator
  2. cd "C:\users\kukha\AppData\Local\Figma
    where kukha - your user name
  3. del /s /q “Figma”
    if they ask something need say “Y”
After all files inside the folder will delete
Now you can install Figma again.
Shifate_Rabby
Suddenly Figma app stopped opening on my pc. Then I have uninstalled it & tried to reinstall now showing this error log. How can I solve this?
Lightshot
Error log: SquirrelSetup.log - Google Drive
BetKor
  • August 25, 2021
Have the same problem 😔
mrezag79
  • August 25, 2021
i solved this.
go to :
C:\Users\ your user folder \AppData\Local/figma
and find the _codesign file , then create an text file and zip it with sendto menu then select that _codesign file and hold shift and drag it into zip file , then delete zip file and figma folder.
now install figma.
good luck
burst
  • August 26, 2021
I uninstalled it and when I tried a fresh install from the downloader on the site it keeps throwing this error. thanks in advance!
2021-08-25 20:45:37> Program: Starting Squirrel Updater: --install .
2021-08-25 20:45:37> Program: Starting install, writing to C:\Users\Mark\AppData\Local\SquirrelTemp
2021-08-25 20:45:37> Program: About to install to: C:\Users\Mark\AppData\Local\Figma
2021-08-25 20:45:37> Program: Install path C:\Users\Mark\AppData\Local\Figma already exists, burning it to the ground
2021-08-25 20:45:38> IEnableLogger: Failed to remove existing directory on full install, is the app still running???: System.UnauthorizedAccessException: Access to the path 'C:\Users\Mark\AppData\Local\Figma\app-101.6.0\chrome_100_percent_IObitDel.pak' is denied.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.InternalDelete(String path, Boolean checkHost)
   at System.IO.File.Delete(String path)
   at Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file)
   at Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1()
   at System.Threading.Tasks.Task.InnerInvoke()
   at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext()
   at Squirrel.Utility.<DeleteDirectory>d__19.MoveNext()
   at Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext()
   at Squirrel.Utility.<LogIfThrows>d__42.MoveNext()
2021-08-25 20:45:38> Unhandled exception: System.AggregateException: One or more errors occurred. ---> System.UnauthorizedAccessException: Access to the path 'C:\Users\Mark\AppData\Local\Figma\app-101.6.0\chrome_100_percent_IObitDel.pak' is denied.
   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
   at Squirrel.Update.Program.<Install>d__4.MoveNext()
   --- End of inner exception stack trace ---
   at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
   at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
   at System.Threading.Tasks.Task.Wait()
   at Squirrel.Update.Program.executeCommandLine(String[] args)
   at Squirrel.Update.Program.main(String[] args)
---> (Inner Exception #0) System.UnauthorizedAccessException: Access to the path 'C:\Users\Mark\AppData\Local\Figma\app-101.6.0\chrome_100_percent_IObitDel.pak' is denied.
   at Squirrel.Update.Program.<Install>d__4.MoveNext()<---
MaximLaFleur
Unfortunately it did not help me as an error pops up the specified folder is empty so you cannot add it to this archive. Maybe I’m doing smth wrong…
Artur_Kukharski
margulan_berkinbayev
Thank You! It really works!
EugeneF1
  • August 28, 2021
Oh God! Thank you so much! It really works
Alina_Nozik
What is "del /s /q “Figma”? Where I can find this?
tank666
  • 4871 replies
  • September 14, 2021
This command must be written on the command prompt.
  • October 14, 2021
