Component interaction "Change to" variant doesen't work
skippybooo
He there, guys.
Playing around Figma for a couple of days, and it’s pretty amazing! But I’m stuck with component’s prototyping actions.
Here is my design.
I’m talking about that tiny vertical switch (“brief/detailed”). It has two variants, each one has interaction to change current variant. But that is not working… I’ve tried everything: resetting instance, making component from scratch, moving it outside nested component, switch property from text value to boolean (On/Off), etc. Can anybody advice me?
tank666
Reset the overrides in the “switch_vertical” instances in all places, and then reload the presentation tab.
skippybooo
  • August 5, 2022
If you mean “Reset all changes” in instance “…” dropdown, no effect.
skippybooo
  • August 5, 2022
hmmm. strange behavior. I’ve just created new empty file, coy that component, make instance and it’s working fine…
skippybooo
  • August 5, 2022
Yury, I’ve just granted you edit permission. May you check it?
skippybooo
  • August 5, 2022
Guys, I’ve finally overcome that bug by copying all (cmd+A) to new empty file. So, now you know what to do.
tank666
Yes it is. But it was necessary to reset in all instances. You missed the “switch_vertical” instance in the “inner” master component.
I did that and it should now work as expected. Just reload the presentation mode tab (right-click on the tab › Reload tab).
skippybooo
  • August 5, 2022
hell… stupid mistake. thank you for your time!
  • September 4, 2022
