Choose different default values for instance swap property
  • December 22, 2022
  • 4 replies
  • 972 views
Antoine
Hi! Currently adding an instance swap property to a variant set element requires this element to have the same value in every variant (same instance, with the same properties if it is itself a variant).
It would be nice to be able to have multiple default values. For example, in a variant that has light and dark theme variations:
  • The light variants will have light elements as default instance value
  • The dark variants will have dark elements (the same) as default instance value
A workaround is to create a different property (“Choose Instance (Light)” and “Choose Instance (Dark)” for example), but it’s limited. Styles overrides are possible in default values, why not properties/instance overrides?
Pavel_Kiselev
  • 438 replies
  • December 22, 2022
Have you seen preferred values when exposing an instance swap property? They allow you to do exactly what you describe
Antoine
  • 145 replies
  • December 22, 2022
Hi Pavel, no that’s not what I’m looking for. Preferred values are amazing to narrow down user options in instances.
What I’m looking for is a way to have multiple default values of the nested instance in the master.
Ivo_Herrmann
  • 1 Would be nice to have different default values for the same instance swap property inside a component set. Same for different texts. Would also be nice to use different default text for one text property.
  • April 26, 2023
