Button component text changes back to default on hover
  • January 27, 2022
  • 4 replies
  • 8119 views
Jip_Asveld1
Hello,
ezgif.com-gif-maker
I created a button component with a hover state. In the component, I added a default text ‘text’ which is also the name of the layer. When I use this component in my design and change the text (‘ADD’) then it changes back to the default ‘text’ when I hover the button in prototype mode. I added a screen recording to clarify the issue
How do I make sure that the adjusted text is maintained after I hover in prototype modus?
Thanks already, Jip
Best answer by tank666
There are layer name mismatches in your components that prevent the text override from being saved. To fix this, simply rename the nested components LightMode/Default/min-width btn and LightMode/Hover/min-width btn to e.g. base-btn.
tank666
  • 4869 replies
  • January 27, 2022
Hi @Jip_Asveld1, could you share an example file?
From this entry, it is impossible to determine the cause and find out how your component is arranged (component structure).
Jip_Asveld1
  • January 27, 2022
Hello @tank666
Here is a link to the file:
Figma – 27 Jan 22
Hope that does give you enough privileges to discover the issue?
tank666
  • 4869 replies
  • January 27, 2022
  • February 26, 2022
