Auto layout vertical padding mix up
  • November 12, 2021
  • 4 replies
  • 742 views
Nikita_Vergis
Every-time I try to add vertical padding above a frame having auto-layout, it adds the padding below instead and vice versa.
If you check out the image I’ve shared below, I added padding below the frame but it has added it above.
tank666
  • 4862 replies
  • November 12, 2021
Apparently your “Frame 45” is rotated 180°.
Nikita_Vergis
Nope, I checked that too. It’s been happening every-time I create a frame and apply auto layout. The orientation of the frames is still 0°.
  • 4706 replies
  • November 15, 2021
Instead of being rotated, it can be flipped. Press Shift + V on it. If that doesn’t help, share the file link.
  • December 15, 2021
