For my Primitives, I have added the Neutral colours as hex codes, light and dark use separate palettes and don’t pull from the same palette.
When I go to map my Primitives to their Semantic names, the dark mode column shows the same colours as the light mode. There’s no way for me to add the dark mode primitives I’ve defined before.
Also, to preview how my design will look in dark mode I have to switch both Semantic/Primitive modes in order to see the theme change.
Is there a better way I could do this?
Here’s a link to view project screenshots:
I’m also particularly interested in understanding how you’re handling different modes. While I can’t provide direct advice, I did come across a fascinating discussion on this topic earlier. I thought it might be helpful for you.
Hoping to see some insightful responses from the community soon!
Toku
Were you able to find a solution for this? I’ve been having trouble mapping the dark mode tokens from my semantic collection to the third tier of component tokens.
