How can I merge two color styles in my style library?
  • February 18, 2022
  • 19 replies
  • 4808 views
Jan_Rehak
Hello community,
I need to update the color styles library. I’d like to merge two color styles into one in order to update all the linking components to one new color. Is this even possible?
Thank you.
Antoine
  • Active Member
  • February 24, 2022
I’m also looking for a way to merge styles. In my case text styles but it’s the same question.
Erling
  • March 24, 2022
I’m pretty sure I’ve done this before by just renaming one of the styles to the same as the other… But in that case it doesn’t work anymore.
Not that that was a good solution anyways, as it could lead to unintentional changes, especially when restructuring styles in groups. So I’d rather want to select two styles, right click and merge.
Maybe anyone knows of a plugin that can do this? If not, I guess the best way is to make the two styles you want to merge the same color, delete one and use the Style Organizer plugin to scan the page. Then you only have to click one button in the plugin to attach unlinked styles to the style. However, if the styles reside in a library, you have to go through every file and run the plugin…
Ivancis
  • March 25, 2022
Having it in separated library and "Merge libraries helps. But only when they are under the same name, AFAIK
What if the library that I want to merge out of doesn’t exist (no original library file), is there a way to do that without merging all the colors manually? The names are already the same.
Carioca_Andre
Any solutions yet? im also looking for a way to do this
Amrit_Shahi
I am also looking for this.
Nader
  • June 19, 2023
Ash.Sharifi
Same issue!
Joey_Brennan
+1 Need This!
Dan_Peterson
  • August 8, 2023
Looking for this as well!
Same question!
Hannah_Taylor
Really needing this as well!
  • August 21, 2023
+1 also need this
Mylene
  • August 21, 2023
Looking for this too !
Sascha_Koeth
+1 also need this
zain3
  • December 19, 2023
I’m also looking for a best plugin to solve this out
Armin_Rouhanian
This Feature is not currently added to Figma, yet. I suggest adding this to the “share an idea” category. and link it to this discussion. If it gets enough votes, it might be added in future updates.
For now, check out the plugin mentioned in this post:
Let me know if this works. or simply mark it as a solution 😃
Joy12
  • July 1, 2024
Also need this! We have font styles that need to be merged
Dennis_N
  • July 16, 2024
