How to fix the 1/2 pixel off on "line object" component on Figma?
  • August 29, 2023
  • 15 replies
  • 5277 views
Rosieway
Hi there, I just discovered that the “line object” on Figma is always 1/2 pixel off. No matter how you adjust the stroke to be in the center, inside or outside.
Is there a way to make it become a full pixel? I want to create a line object and make it into component. However, the outline of the component will never wrap the line object to its edge but always 1/2 pixel inlined.
Here is what it looks like:
Thank you!
Best answer by tank666
This is a GIF from the “Explore auto layout properties” article in the Help Center.
MartinBajac
  • August 30, 2023
Line vectors are created with 1/2 pixel to it’s left of the center line and another 1/2 pixel to the right of the center line. When creating components, Figma takes the start point of the center line of the vector and the last point of the center line of the vector, and creates the box you showed above, with half a pixel on the outside. Taking this into account and further research, I don’t think there is an appropriate solution for this issue.
tank666
  • August 30, 2023
Wrap your vector with a stroke in an auto layout frame or add an auto layout property to your component and
Figma Learn - Help Center
Jairo
  • August 30, 2023
Your Stroke is not closed, so options like “Inside” or “Outside”, cannot be applied.
Think of it: Inside relative to what?
Jairo
  • August 30, 2023
If you want to draw a stroke that is 1px wide and don’t fall into the subpixel space, then you have to make your vector into that subpixel:
Note: The red mark shows the vector pen position when approaching to the subpixel grid. The shape on the left succesfully shows a 1 px vector that fills an entire pixel
With the pen tool you can draw directly into the subpixel grid, so when applying a stroke to the vector created it will fill an entire pixel.
Basic shapes will be created inside the regular pixel grid.
To make them go subpixel you can either alter the coordinates X/Y by 0.5px or enter in vector edit mode and move the nodes to the subpixel grid.
Rosieway
  • August 31, 2023
Thanks so much @tank666 The auto layout stroke included works just like magic!!!
Bryce_Driesenga
Okay, you gotta tell me what you recorded that GIF with!
Rosieway
  • August 31, 2023
@tank666 Curious +1
tank666
  • September 1, 2023
Bryce_Driesenga
Dang, the quality is great. So curious how they optimized it.
Bryce_Driesenga
@Rosieway I don’t know what they used, but I did come across https://gif.ski/ and it seems to do pretty great converting videos to GIFs!
Rosieway
  • September 6, 2023
Thanks for the link @Bryce_Driesenga ! The quality is really amazing!!
Oliver_Schwaiger
I am curious @tank666, is this also something that is possible in CSS? Or what is the equivalent in code to achieve this – if you happen to know that.
tank666
  • November 22, 2023
Border in CSS are directed inside the container. That is, the border property in the CSS = include a stroke in the layout in the Figma auto layout properties.
Oliver_Schwaiger
Ok yeah I thought so, but I do not understand why this is different in Figma?
Rosieway
  • November 27, 2023
Thanks for responding to the CSS related question. From what you said, it seems like Figma can reflect what we do on CSS level right?
If so, I got another question (not sure if it’s related), if today we’re going to create a square card that has the radius at 5px with both width and height in 100px. We can create that on CSS right away! But that’s say, if we wanted to enlarge the square into 200px by 200px on CSS, this square’s radius should still remain 5px right? Unless we change the value on the radius.
I ran into another situation that I shared on this post: Resizing an auto-layout and constraints set up elements without stretching on corner radius?
I wonder if it’s the same logic? Thank you very much!!
