Website screenshots added into Figma file appear pixelated
  • April 5, 2023
  • 10 replies
  • 3613 views
I’m adding in website screenshots of full webpages to a Figma file they appear very pixelated. (for example all are 1440px wide x 6000px tall x2) These are screenshots that are being taken on a retina macbook display so they are 2x resolution.
When I open them on my computer normally they are not pixelated.
What’s going on here?
There is no information or help for the issue that I can find.
Stephane_Popout
There is already a blurry images discussion (link at bottom)
A user proposed to use the “Insert big image” plugin to avoid this
  • April 6, 2023
This is a similar but different issue, the image added are pixelated right when I drop them into figma, they don’t become pixelated/blurry at a later date.
Yehia
  • April 6, 2023
@CR_chlo Have you followed these steps here in the Image loading and performance issues guide?
  • April 7, 2023
So, I’ve found why this happens, Figma downsamples any images over 4096 px on any edge.
Was this always the case or is this new?
  • April 7, 2023
Hey there,
This was always the case. There’s also a feature request to disable image resizing here: Option to disable "Image resized" when large images are brought in
Kast_Bettina
I am adding screenshots with max 1920px into Figma and see everything pixelated. Another issue is that added screenshots in FigJam are not visible to all people I share boards with, forcing us to use traditional screen sharing which defeats the purpose of sharing boards.
  • April 25, 2023
Hi again,
The forums are primarily run by the community. You’ll get more specific help by reaching out to the support team directly: https://help.figma.com/hc/en-us/requests/new
Kelsey_Waara
  • January 16, 2024
I found a work around for this: try the “Insert Big Image” plugin! It’s still a pain point to not be able to just drag an image into my Figma file, and instead I have to use the plugin, but it works.
Donji_Yamada-Dessert
You can also use this site to split up your image into smaller parts easily:
imgonline.com.ua
jamesjohnhenry73
Thank you. It’s very helpful.
