Bug with Cmd + Shift + R (paste to replace).
Expected result: When using Cmd + Shift + R, the target frame should be replaced with the one I am pasting.
Actual result: If I paste a frame containing text in the format of an email address, and the target frame also contains text, then it deletes the target text-frame altogether, and pastes nothing.
Normal Example:
- I click on a text-frame containing “asdf” (the frame, not the text inside).
- I copy it, then click on a target text-frame, and press Cmd + Shift + R.
- The target text-frame is replaced with the text-frame “asdf”. That works great.
Problem Example:
- I click on a text-frame containing “asdf@asdf.com” (the frame, not the text inside).
- I copy it, then click on another target text-frame, and press Cmd + Shift + R.
- The target text-frame is deleted. Nothing gets pasted.
This is the formula to create the problematic text:
[any letter or number]@[any letter or number].[any letter or number]
Exceptions:
- Symbols do not break the functionality.
- Pasting a piece of problematic text to replace shapes or non-text frames still works.
These break when pasting to replace a text frame:
“asdf@asdf.com”
“a@asdf.c”
“asdf@asdf.1”
“1@asdf.c”
These do not break when pasting to replace a text frame:
“asdf@asdf.#”
“#@asdf.com”
“$*@asdf.com”
My specs:
– Figma Desktop App version 116.18.6
– macOS Sonoma 14.3 (23D56)
Thanks!
