Arrow Up/Down to select style from auto-complete has stopped working
Hampus_Svallfors
Hi community!
This is tricky to explain. But sometimes the arrow up/down seem to simply move the Caret Position in the input field to the beginning or the end, instead of changing the selected item in the list. If I hover the list, the up and down selection starts to work again.
Feb-06-2024 17-18-56
Using arrow down to select from all auto-complete searching is deep in my muscle memory, as I’m sure many of yours as well, so this issue has become somewhat if a nuisance to me. I never realized how many times per minute I searched and selected a style or variable before this started not to work.
Could this be something with my trackpad, keyboard, computer etc. Or is it something anyone else also has experience?
Best answer by y_toku
Thanks for the feedback and I shared these with our internal team. We cannot guarantee if it’s prioritized but we will let you know if there is anything I can share with you.
Let me merge into an existing one:
Thanks!
Toku
Hampus_Svallfors
Another GIF showing the caret just going back and forth inside the input field when I press arrow down/up:
Feb-06-2024 17-32-44
  • 2436 replies
  • February 8, 2024
Hi there,
Thanks for flagging. I could reproduce the issue! I will share this with our internal team. can’t guarantee anything on our end, but I will give some visibility to our team for consideration.
Toku
Jacek4
  • 12 replies
  • February 9, 2024
have exactly the same issue. Working on the macbook pro 14 m1. It started about 2 weeks ago I guess.
Phil_Larsen
  • Active Member
  • 130 replies
  • February 16, 2024
When typing in the styles search bar, I used to be able to tap the up/down arrow to navigate between the results in the search. Now those arrow keys go to the beginning or end of the text in the search bar. This requires me to use the mouse to click on the object I am trying to select rather than being able to use just the keyboard.
PasDee
  • 4 replies
  • February 22, 2024
fill-selection-nope
My issue is that whenever I type a search in to the fill selection panel, I cannot, for the life of me, navigate with up and down arrows anymore. This used to work all the time, at least for the last 2 years.
Instead of going through my search results, it just goes to pos1/end of text area.
This requires me to get my hands off of my keyboard and back to my mouse, just to select what’s like 20px below the text box.
Tab cycles through EVERYTHING EXCEPT the actual content of that panel. Really asking myself what this is about.
PasDee
  • 4 replies
  • February 22, 2024
Just created a new post since I could not find this one. Same issue here. Started around when you posted, still persists, drives me crazy.
Not even Tab is of any use.
Brian_Saunders
I am also having this issue and would appreciate if Figma could look into it. Weirdly the keyboard handling works when traversing some libraries, but not others. This is a big productivity killer for me as well.
Brian_Saunders
I’m also struggling with this issue and it’s taking me out of my flow. It only started within the last couple weeks and I hope it is fixed soon. For me the issue only happens when trying to navigate search results from a certain library.
Phil_Larsen
  • Active Member
  • 130 replies
  • March 11, 2024
Any updates on this? It still messes me up
  • 2436 replies
  • March 12, 2024
Thanks!
Toku
LEFEBVRE_Jil_DES_OPS
I’d like to upvote this topic, such a small big annoying thing that’s not working anymore.
wdimondi
  • 5 replies
  • June 24, 2024
This is still an issue.
Marie_Rang
This just started for me and the proposed “solution” of hovering over the list doesn’t work. Is this because of the new UI updates? Because if so it really sucks.
wdimondi
  • 5 replies
  • June 28, 2024
Lol that defeats the entire purpose of using arrow keys when searching. You’re now asking me to remove my hand from the keyboard to use the mouse so I can use the keyboard again 🥴 🥴 🥴
Hampus_Svallfors
I think it’s a keyboard localization issue and therefore very hard (or at least very time consuming) for the Figma team to investigate and reproduce. There has been similar issues in the past where some shortcuts only worked with US keyboards for example.
People who have reported on this issue, what system language and keyboard layout do you have? (I use Swedish system language and Swedish keyboard layout).
Marie_Rang
I use the Swedish keyboard layout and switch between Estonian and Danish keyboard input languages and system language is English. No idea, but my error only occurred the day they announced UI3…
Jia_Lin_Tan
Whenever I change a color of a text for example, I will type in the color name and search it in my library. After searching I will use the keys [down] to navigate to the right shade. After the update the up and down key doesn’t work anymore and it is making color selection more cumbersome.
It still works for text style selection so maybe it is a bug? Is anyone experience the same?
wdimondi
  • 5 replies
  • July 11, 2024
Not sure if this is a reasonable excuse. Keyboard functionality is a critical productivity component in creative applications.
Julie_Mitchell
Randomly, also, I cannot use the Command + (zoom in) option on my keyboard when I’m in this view, but Command - (zoom out) works fine.
Julie_Mitchell
To add to this Arrow up/down issue, I used to be able to move images with the arrow keys, to be more precise in the movement, when I was in the crop option of the fill window. I can no longer do this and only move the image around using my mouse. This is driving me crazy as it is not as quick/easy/precise to make the crop I want. Please tell me that this will get fixed to being able to use the arrows on my keyboard again.
Hampus_Svallfors
This has been resolve for me. The interaction is working as expected, not sure if it was Figma, or me updating to Sequoia, or changing system language to English. I’m glad it’s working now 🎉
