Is it possible to change the blend layer opacity to 0% via the API?
  • November 6, 2023
  • 353 views
Hi all,
I’m creating a plugin that draws everything to the canvas using API commands. I can’t seem to work out how to create a node with an opacity that isn’t 100%. I’m aiming to create a node with properties equal to the screenshot below!
I’m setting blendMode and fills at the moment:
textNode.blendMode = “PASS_THROUGH”;
textNode.fills = [{type: ‘SOLID’, color: rgbTextColour}];
Screenshot 2023-11-06 at 10.24.12|464x224
Many thanks,
Antony
Best answer by tank666
Change the opacity property.
figma.com
tank666
  • November 6, 2023
figma.com
  • November 6, 2023
Thank you so much Tank! Simple question, such a simple answer.
