🆕 Organize your pages with dividers & multiple page moves! 🎉
  • May 14, 2024
  • 23 replies
  • 43009 views
You can now organize your pages any way you want:
  • Turn a page into a page divider with hyphens, en/em dashes, asterisks, or spaces
  • Hold shift to select multiple pages and move them around
twitter.com
  • May 14, 2024
2 posts were split to a new topic: Add a name for each divider
Hi, this is a great mini feature!
But do you know if you can still create spacing? I’d usual tap the spacebar on a new page to give me a blank “space” between pages or categories.
It’s not obvious from the above if you can do that now and how.
Thanks!
  • May 15, 2024
Love this feature 🫶 Now I have the song stuck in my head 🙃
Vero5
  • May 15, 2024
Looks like this now creates a divider, just like the hyphen does.
Yeah, it was the first thing I tried 😀 … hopefully you can still do this somehow. If not, it would feel like it makes the divider-line a less useful update for me. 🫠
Tosin_Afolabi
Brilliant! Thanks.
Alamaki
  • May 17, 2024
Undiscoverable unless you try to use layers as makeshift separators and happen to name them so that it triggers conversion to separator. Explicitly added named groups would be more useful and could work just like grouping layers.
Hi, this is great!
I wonder, however, if it would be possible to support this via the Plugin API as well? It now seems like when you programmatically change the page name to “—” (or spaces, dashes or asterisks), the renamed page still stays as a regular page, instead of a nice separator line.
Jenny_Bellin
Doesn’t work for me. It still displays whatever I type in (—)…
Fullerton_Andrew
Tips for anyone looking to create or edit a divider:
  • An already created divider can be moved by dragging it to a new location in the pages list. You don’t just have to move the named pages around the divider.
  • Dividers can also be deleted (or renamed if you made the change by accident) by right clicking on the divider.
  • Pages need to be empty to become a divider. If you have any layers in a page the name will remain and not turn into a divider (ie **** or ----).
Weirdo
  • Active Member
  • May 19, 2024
Great feature but undiscoverable, why not clicking on the plus icon and choose between new page or divider?
-or-
Adding the divider icon next to the plus icon.
And what about folders? The plus icon can solve it as well.
Folders are a huge feature to organize the pages.
r_sh
  • Active Member
  • May 20, 2024
It would be very helpful to either have folders of pages, or the ability to label a divider (like “-----LABEL-------”) so that the divider itself provides some contextualization.
Kunlatida_Lawilai
I just tried that but it doesn’t work.
EliseLnw
  • May 23, 2024
“3 hyphens then press enter” works for me.
Is there a way to add a title of section ?
Is there a way to add this also via API? if i use page.name = “—” it does not work. Thanks!
  • May 28, 2024
A post was merged into an existing topic: Add a name for each divider
Jan_Jones
  • June 6, 2024
A completely useless feature without the ability to label.
“Oh sections, what does this section mean?..”
  • June 13, 2024
Nice, but why not use the Pages ‘+’ to provide a quick drop down menu with 2 options: page, divider.
Using ‘—’ is hard to discover, unless users have used this workaround before to organize pages.
JettyLou
  • June 28, 2024
@Andy_Leevey I also miss being able to have that extra space between my pages… @dvaliao Please bring back the blank page names using spacebars 😭
JettyLou
  • July 4, 2024
There is a solution here in this post Bring Back Blank Page Names
CristinaS
  • July 31, 2024
Dividers should also be visible in ‘Dev mode’.
Emily_Gerrity_ALLEGIS_GROUP_HO
PLEASE do some experimenting with this, it would be really useful to a lot of people’s workflows if we had better control over how our files are structured.
Trying to get a whole team on board using similar file structures is tough.
  • ability to create file structure templates so when my team member opens a new file, they don’t have to duplicate from a template, and everything stays consistent
  • If you go browse community, how many files do you see where designers are using emojis to help with visual overload? I would love to be able to create standard labels I can easily apply to pages without searching for emojis 💠 🚫 ✅
  • how often do you see people indenting using 5-10 spaces or alt characters? using dashes around a page name because dividers aren’t useful if you still have to make a label page
  • PLEASE LET ME COLLAPSE SECTIONS so I don’t have to look at my archive or other admin pages
The left panel suffers from so much visual overload. I absolutely hate having to scroll through it.
