Adding elements to component instances
  • July 3, 2024
  • 1352 views
I see this question has been asked before, but I’m wondering if anything has changed (looks like it was last asked in 2022). Say I have a master component containing 4 separate ‘blocks,’ with each block including an icon, body copy and a link. If I instert an instance of that component in my design, I know that I can easily delete one of the blocks and the component will adjust with no issues, but what if I want to add in say a 5th block…are we still unable to do that?
  • Figmate
  • July 24, 2024
Hi @team_alaska_design, Thank you for reaching out about this!
Upon testing on my end, it appears that this is not possible at the moment.
You might already be aware of a potential workaround, which involves detaching the instance in your file and adding elements to the frame.
I understand this requirements, and this would indeed be a valuable feature request so I move this post in to “Share an idea” category. Also, I came across a similar feature request from other community members in 2022 here:
Additionally, here is another similar request:
If you agree, I can merge your post with one of them (and reopen it) to increase visibility. Please let us know if you support this idea.
Thank you once again for your valuable input!
