Why is image DPI doubled when exporting with a multiplier?
  • September 25, 2023
  • 6 replies
  • 1793 views
Sean_Cooley
When exporting using @2x, @3x, etc multipliers, Figma not only doubles the resolution (width x height) it also doubles the DPI of the image.
I’ve been told by Figma on twitter that this is by design. My question is why?
DPI is useful for print, but digital screens and devices completely ignore DPI when rendering an image. All they care about is the resolution. I know this sounds wrong, but it’s a fact. An image that is 100x100 will display the same on screen regardless of it is 72 or 144 DPI.
High Density screens rely on larger resolutions (i.e. double the size, triple the size) and then pixels are doubled or tripled to get the high-quality look of retina or High DPI images.
Also, if screens really did respect DPI, then doubling the DPI would be enough to support these screens. There would be no need to also double the resolution.
By doubling both, you are effectively making an @2x image @4x. You’re also making the resulting exported image unnecessarily large.
We have certain systems that require us to upload images at 72 DPI, and because Figma doubles the DPI when using a multiplier, we have had to resort to exporting using the “w” & “h” short codes.
Is there any way Figma can change this functionality, or give us control over the DPI?
ksn
  • 1775 replies
  • October 3, 2023
Hiya! So full disclaimer: I don’t have an exact answer for you directly. There may be other community members or mods that can answer this better than I can.
I think this older topic may be helpful for context on how DPI functions in Figma (related to exports as well as other things): https://forum.figma.com/t/export-losing-quality-even-using-png-and-2x-higher/3541/61
Sean_Cooley
  • 12 replies
  • October 4, 2023
Hi, yeah this post unfortunately doesn’t touch upon what I’m talking about. This is specifically related to how Figma manipulates DPI of exports, despite devices ignoring this info when rendering the images on screen.
Sean_Cooley
  • 12 replies
  • February 22, 2024
Bumping this topic. After doing some more research it seems Figma uses the DPI to determine if the image is high density or not when re-importing it.
Just want to re-iterate that DPI is for print and not screen displays, so there is no reason to double the DPI of the images for regular export. All screens will ignore this setting and rely on the resolution of the image to handle pixel density. Sometimes it makes @2x, @3x images unnecessarily large.
Ben89
  • November 12, 2024
I am also running into this issue. Im trying to upload a document to a web uploader and the size is 3x the acceptable dimensions, despite my artboard and files showing the correct size and being exported at 1x. I’ve tried to run a few plugins but they’re only to help set up artboards, not for exporting correctly.
Sean_Cooley
  • 12 replies
  • April 24, 2025
Following up on this thread from a while ago. Are there any plans to fix this? Files exports are unnecessarily large because of this feature (bug).
Rob_Marquardt
  • 13 replies
  • April 24, 2025
I’m not sure where you’re getting larger file sizes as a result of DPI. If I’ve got 1920x1080px images at 36, 72, 144, or 1,000 DPI they’re all going to be the same file size.
If I export a 1920x1080 frame @1x, 2x, and 3x, I get:
  Size in pixels DPI Size in points
1x 1920x1080 72 1920x1080
2x 3840x2160 144 1920x1080
3x 5760x3240 216 1920x1080
There’s no doubling of doubling going on as a result of the DPI value. I can understand why Figma is doing this though, because if I drag those exports back to the canvas, they all get placed at the same 1920x1080 visual size (with the higher DPI versions having greater detail).
If the DPI value is affecting a web uploader or other external utilities in your workflow, I’d say use exiftool (or its equivalent) to strip all the EXIF data from the file which will default it to 72 DPI without otherwise changing/recompressing the image.
