Why do my components' scroll behavior "Position" always reset to "Scroll with parent"?
Kenny_Xiong
Is this just the default behavior of components when put inside a frame?
Example, I created a navbar component and have it’s Scroll Behavior - Position set to “Fixed.” When I drag it from the assets panel the Scroll Behavior will reset to “Scroll with parent”. The component does not keep the “Fixed” setting… I know I can just copy and paste to preserve that setting…but it makes workflows slower because I have to find my style sheet and copy the main component every time I make a new frame for a different screen.
Thanks for any answer.
Best answer by djv
Hey @Kenny_Xiong, so sorry for the delayed reply!
I went OOO on January 31st.
We’re not able to see the exact naming of your components with View only access, but please try this workaround. Issues with scroll behavior are usually related to the limitations with the new State management for prototypes .
For most users, this issue is caused when objects do not share matching names. In order to share a scroll state, they need to have matching names according to this rule.
  • 4871 replies
  • January 29, 2024
Hey @Kenny_Xiong, sorry to hear this is happening!
It’s hard to understand and be sure what’s happening without seeing your file.
Are you able to provide a link so that we here in the community can take a closer look and try to reproduce?
Kenny_Xiong
Sure, I’ll share a link and some images. I’m just trying to update my portfolio with a small number of screens, but for larger projects it might cause some confusion.
Shared with view only, I won’t mind opening it for editing.
Link to my project
My navbar component has a it’s scroll Position set to “Fixed.”
If I copy and paste the main component from a sticker sheet, it keeps its position.
navbar-fixed-OK
Navbar component in the assets panel won’t retain a fixed position.
After inserting an instance of the component, the position is reset to “Scroll with parent.”
  • 4871 replies
  • January 30, 2024
Thanks, @Kenny_Xiong!
We’ll pass this along to our prototyping team to investigate.
Kenny_Xiong
Thanks for your reply! Sounds good.
  • 4871 replies
  • February 21, 2024
