Thanks for reaching out! Is this a shared style? If so, you might need Edit access to make changes. Could you please confirm?
If it’s a local style, could you let me know the font family name? I’m wondering if it’s a variable font. If it’s a static font, you’ll need to replace it. You can find more information here:
If the problem persists, would you be able to share the file link with access to support-share@figma.com? It won’t affect your billing. I hope I can investigate it further.
Thanks for your patience! I’ve reviewed your file and tried to find the issue, but unfortunately, I couldn’t determine the cause. It might be a current limitation of the feature, but I’m not completely sure.
Could you please submit a bug report with the steps that led to this issue? You can do so by following this link:
