Using Emailify, how can I change the border radius of a button?
Chuck
I’m using Figma with the Emailify and I’ve added some text with a button.
Question - I can’t figure out how to change the button radius using the UI. If I export, I can go into the html and change the CSS by hand, but that’s not until after I export. Also, I can see the CSS for the button in the inspect tab (image below) but it’s not editable.
Nelson
  • April 21, 2022
Hey Chuck! I don’t know if the plugin makers check this forum. I’d recommend posting your feedback directly in the comments section of their community plugin page: https://www.figma.com/community/plugin/910671699871076601/Emailify-HTML-Email-Builder
It looks like they are monitoring those comments. Best of luck!
Chuck
  • April 21, 2022
Hi Nelson.
Do you know if there is a forum somewhere to get live help?
ntfromchicago
Unfortunately none I’m aware of, but they have an email contact on their support page.
Click/ choose the button on which you want to change the border-radius, on the panel on the right, within the Frame section, under Vertical Resizing, you’ll find Corner Radius, just enter the number you want to and you’re done!
