WHAT I WANT TO ACCOMPLISH
Please excuse my poor English.
I want to output CSV files for items such as Text in Figma, but I wanted to separate the files, so I used this as a reference to set up ts-loader and webpack.
I am new to developing Figma plug-ins, but I managed to complete the process of compiling text and other items and outputting them to the console.
After that, I encountered an error where the output in CSV would use fs, but here I encountered an error where fs could not be imported.
THE PROBLEM AREA
//The problem area
import * as fs from 'fs'; // Here!!
export class DownloadCSV{
public save(filename: string = "out.csv"){
fs.writeFileSync(filename, this.text);
//manifest.json
"name": "XXX",
"id": "1338758441514588489",
"api": "1.0.0",
"main": "dist/main.js",
"capabilities": [],
"enableProposedApi": false,
"editorType": [
"figma",
"figjam"
"ui": "dist/ui.html",
"networkAccess": {
"allowedDomains": [
"none"
package.json
"name": "XXX",
"version": "1.0.0",
"description": "XXX",
"private": true,
"scripts": {
"analyze": "npx webpack --mode production --profile --json > profile.json && npx webpack-bundle-analyzer profile.json build",
"build": "npx webpack --mode production",
"build:watch": "npx webpack --mode development --watch",
"lint": "npx eslint",
"prettier:format": "npx prettier --write 'src/**/*.{js,jsx,ts,tsx,css,json}'"
"author": "",
"license": "",
"devDependencies": {
"@figma/plugin-typings": "^1.85.0",
"@types/express": "^4.17.21",
"@types/node": "^20.11.20",
"ts-loader": "^9.5.1",
"typescript": "^5.3.3",
"webpack": "^5.90.3",
"webpack-cli": "^5.1.4"
"dependencies": {
"@types/fs-extra": "^11.0.4",
"@types/react": "^18.2.60",
"@types/react-dom": "^18.2.19",
"@types/three": "^0.161.2",
"react": "^18.2.0",
"react-dom": "^18.2.0",
"three": "^0.150.1"
//tsconfig.json
"compilerOptions": {
// Three.jsがES5未サポートなので、割り切って比較的新しい仕様でビルドする
"target": "ES2015",
// TSのモジュールはES Modulesとして出力
"module": "ES2015",
// JSXの書式を有効に設定
"jsx": "react-jsx",
// node_modules からライブラリを読み込む
"moduleResolution": "node",
// これの設定も必要 デフォルトインポートの有効化
"allowSyntheticDefaultImports": true,
// 厳密モード
"strict": true,
"lib": [
"ES2023",
"DOM"
"typeRoots": [
"./node_modules/@types",
"./node_modules/@figma"
"include": ["src/**/*.ts"],
//webpack.config.js
module.exports = {
// モード値を production に設定すると最適化された状態で、
// development に設定するとソースマップ有効でJSファイルが出力される
mode: 'development',
// ↓コメントを解除すればビルド時のエラーは消えますが、Figma実行時に「requireが使われている」というエラーが発生します。
//target: 'node',
// メインとなるJavaScriptファイル(エントリーポイント)
entry: './src/main.ts',
output: {
// 出力ファイルのディレクトリ名
path: `${__dirname}/dist`,
// 出力ファイル名
filename: "main.js"
module: {
rules: [
// 拡張子 .ts の場合
test: /\.(js|ts|tsx)$/,
//exclude: /node_modules/,
// TypeScript をコンパイルする
use: 'ts-loader',
// import 文で .ts ファイルを解決するため
// これを定義しないと import 文で拡張子を書く必要が生まれる。
// フロントエンドの開発では拡張子を省略することが多いので、
// 記載したほうがトラブルに巻き込まれにくい。
resolve: {
// 拡張子を配列で指定
extensions: [".ts", ".tsx", ".js", ".json"],
//modules: [`${__dirname}/src`, 'node_modules']
// ES5(IE11等)向けの指定(webpack 5以上で必要)
target: ["web", "es5"],
PROBLEM/ERROR MESSAGE BEING ENCOUNTERED
//console
PS C:\Users\XXXX> npm run build
Debugger attached.
> plugin@1.0.0 build
Debugger attached.
Debugger attached.
assets by status 2 KiB [cached] 1 asset
orphan modules 4.52 KiB [orphan] 3 modules
./src/main.ts + 3 modules 5.94 KiB [built] [code generated]
ERROR in ./src/DownloadCSV.ts 1:0-25
Module not found: Error: Can't resolve 'fs' in 'C:\Users\XXXX\src'
Parsed request is a module
using description file: C:\Users\XXXX\package.json (relative path: ./src)
Field 'browser' doesn't contain a valid alias configuration
resolve as module
C:\Users\XXXX\src\node_modules doesn't exist or is not a directory
looking for modules in C:\Users\XXXX\node_modules
single file module
using description file: C:\Users\XXXX\package.json (relative path: ./node_modules/fs)
no extension
C:\Users\XXXX\node_modules\fs doesn't exist
.ts
C:\Users\XXXX\node_modules\fs.ts doesn't exist
.tsx
C:\Users\XXXX\node_modules\fs.tsx doesn't exist
.js
C:\Users\XXXX\node_modules\fs.js doesn't exist
.json
C:\Users\XXXX\node_modules\fs.json doesn't exist
C:\Users\node_modules doesn't exist or is not a directory
C:\node_modules doesn't exist or is not a directory
@ ./src/SearchScreen.ts 2:0-38 13:20-36
@ ./src/main.ts 1:0-37 36:24-39
webpack 5.90.3 compiled with 1 error in 2429 ms
Waiting for the debugger to disconnect...
WHAT I TRIED
I have searched for 2 weeks on stackOverflow and other sites to find the cause, but I am frustrated.
I am wondering if Figma and Webpack are incompatible, but I have no idea what the cause is or how to fix it. I have no idea what the cause is or how to fix it, so I am asking for your advice on what I should do.
Thank you in advance for your answer!!
ADDITIONAL INFORMATION (FW/TOOL VERSION, ETC.)
node v20.11.0
