Support for relative size units (vw, vh &c)?
  • February 9, 2021
  • 26 replies
  • 16956 views
Peiran_Tan
Is there a plan for Figma to support relative font size units, such as vw, vh, vmin, vmax, etc.? The design system I’m working at is trying to add fluid font size calculations to bigger title sizes, and Figma’s native support for these units would be extremely helpful.
I’m also working separately on a plugin that converts inputed relative units to px values, but it seems Figma’s API won’t support background-running plugins that observes text layer changes. Any thoughts on making the plugin more useful?
  • February 9, 2021
There is no way to do that, so feel free to change your topic to a feature suggestion and move it into #product-ideas or just create a new topic there.
madmonkey
  • February 10, 2021
Seems like the plugin linked below is your solution.
  • Text Resizer helps you update your designs quickly and flexibly with respect to the base font size defined for 1rem …
Figma
Hmmm, wait a moment, maybe you mean fluid resizing font relative to the container size. I haven’s seen support for this in html/css either, so doubt it will be possible in Figma. I may be wrong.
Peiran_Tan
  • February 10, 2021
The vw, vh, vmin, vmax units define font sizes in relation to their viewport sizes. For example, if the viewport width is 1600px, 1vw equals 1600/100 = 16px.
Jc_Martel
  • March 31, 2021
+1 - I do have the same issue. I would love to have a better auto-scale (fluid) fonctionality in Figma… and not just fonts, but padding, containers, border-radius, etc.
I would add that being able to set a base px value equal to 1em and then use ems/rems when designing, we could save a lot of time not having to redesign in for all screen sizes. It would be nearer what a developer would have to build.
Imagine setting this is your design library and make it work for anything you build.,.ahhhh, a dream.
Neil_Roose
  • September 11, 2021
+1. This is a badly needed feature. Why have to leave it to the developer to calculate these things?
Timea
  • October 13, 2021
Agree, it would help a lot! Designing with pixels and coding with relative units creates a big disconnect between design and engineering, and makes at least one of these teams’ life harder.
Matteo_S.L
  • January 16, 2022
+1 this, fluid font size
Nic2
  • March 9, 2022
Hi, I ran into the same problem. I got tired of doing it manually, so I wrote a python script that converts px to vw or vh and saves it as a new file . You can find it on GitHub at nicstephens/pxtovw
XavierV
  • August 25, 2022
Yes relative size would be very usefull.
Would love to set sizes based on rem’s, vw’s or grid %'s. Text block 70% of div.
Daniel_Castro_Maia1
Would love this too. Not just for font size, but for everything. So many of the web elements I design are dependent on the screen width, like setting a container to 90vw, an image inside it to 25%, etc. Things are hardly a defined pixel size if you want a responsive design.
s.zababurin.v
Is there a possibility to see support for vw, vh and set unit scale for rem in vw and vw in the future?
Without this, it is impossible to make a modern layout of applications.
It would help a lot.
  • October 5, 2023
Yes, please !!!
weird its not supported by default
100% needed feature
hefler
  • January 25, 2024
+1! Three years and still going.
@Peiran_Tan Would it make sense to update the title removing “fonts”? I understand that your case was initially related to fonts, but in CSS these units are for most elements, as many have already pointed out. I think it would broaden the scope of the feature and perhaps gather even more votes?
  • February 3, 2024
+1 really needed
  • March 25, 2024
Relative units are already introduced in Elementor, Framer. Why is Figma so late, I can’t stop wondering. Introducing em, rem, %, vh, vw for whatever object with editable base of 16px will make responsive design a walk on the clouds for both designers and developers. Now it’s quite a struggle and very time consuming. Has anyone seen any comment from Figma on this? Do they plan to upgrade to relative units ever?
Jesus_Vera
I’m still dumbfounded this hasn’t been deployed yet.
  • May 13, 2024
This is a very necessary feature.
Ge0
  • June 28, 2024
+1 Strongly needed. For instance, during development, I always use the ‘calc’ function for mobile sizing. For example:
@media screen and (max-width: 479px) {
    html {
        font-size: calc(0.75rem + 0.42vw);
This method is efficient and generally ensures that everything fits perfectly with minimal adjustments. The challenge, however, is keeping the mobile designs in Figma synchronized with the actual scaling used in the developed version. Therefore, utilizing relative size units would be optimal, especially when combined with ‘calc’ to mix different size units. Additionally, incorporating the frame width as ‘vw’ should be quite feasible. It should also be possible to set a base font size in Figma for specific frame widths.
Please add 😇
  • June 28, 2024
Hey All, thanks for the feedback and sorry for the lack of acknowledgement here!
We’ll pass this thread onto our team for future consideration.
Theo_Rosendorf
It’s not for Figma but we have a JS script that does this very thing, typesetting based on container width:
textblock.io
And we’re currently working on a release candidate that works properly in React.
Matt_Willett
  • April 16, 2025
This would elevate the usefulness of figma to the next level. As others have said it is added pain when handing over to developers to explain what these units are and how to use them.
The growing support for container units also makes this easier to support https://developer.mozilla.org/en-US/docs/Web/CSS/CSS_containment/Container_queries#container_query_length_units
Patrick_Hussey
Another +1 from me.
Julian11
  • May 8, 2025
Wow this topic is 4 years old! I was just searching what others were saying as my frustration with the latest Config conference didn’t have this update. I was playing around with the Gris and wanted to set 1fr and bupkis. Relative units please!!!
