Prototype gets stuck
  • January 18, 2022
  • 8 replies
  • 1424 views
Tomas_Andriskevicius
Hi people, can anyone advise what to do? Everytime I do a prototype for a specific project, it gets stuck when running it. It helps when I remove all interactions, but when I do prototyping the issue happens again.
Best answer by tank666
Hi @Tomas_Andriskevicius!
I also failed to run “Flow 4”. When I opened the file, I noticed that you are using a lot of vector objects in the mask (Frame 1214132462, green squares in the screenshot), removing which the prototype runs as expected.
You can try removing unused objects from the above frame (and all copies of it) or rasterize these objects.
  • 4710 replies
  • January 18, 2022
What do you mean by “gets stuck”?
Prototype gets frozen, can’t scroll or navigate
  • 4710 replies
  • January 18, 2022
Does it happen in a specific file or in all files? Can you show an example?
sure, here is the prototype: Figma
  • 4710 replies
  • January 18, 2022
The prototype isn’t even loading for me. It is either overloaded with objects and images or just has some internal breakages. I advice you to contact Figma support with this issue, community probably won’t be able to help here (especially if this is a bug in Figma).
  • 4873 replies
  • January 18, 2022
  • 4710 replies
  • January 18, 2022
Wow that’s some intense masking! Yeah no wonder Figma dies trying to load them.
  • February 17, 2022
