I have an unpublished plugin that stops working, whenever Figma update is released. Do you know if I can get notified in advanced about the update and what it will have impact on?
Example: The plugin allows to export creatives with their properties externally. So, whenever there’s a change to the approach to the properties of the elements, the plugin stops working correctly.
Thanks!
So, what you are saying is that I can only view the updates after they were released and there is no sufficient way to prepare for it in advance?
That’s right! But usually Figma updates don’t break plugins/widgets. If you could tell more about the errors you encountered, then you could probably find the cause or send a bug report to support.
