Interactive components
  • September 21, 2023
  • 4 replies
  • 263 views
I’ve followed this tutorial https://www.youtube.com/shorts/yz2orfyg6ck to learn to use Interactive component, but the prototype doesn’t move.
I also don’t have the option of enable interactive component, but I read that it’s not showed anymore cause now it’s automatic. But why it doesn’t work to me?
Best answer by djv
Thanks, Laura!
A couple of our team members took a look at your file, and it wasn’t working, because it’s rotating the parent frame of the instance. If you remove that rotation so that they’re all 0 and then rotate or edit the inner circle it should work as expected.
We edited the file a bit to demonstrate. It looks a little wonky with the smart animate, but it works. Hope this helps!
  • 4871 replies
Hey Laura, thanks for reaching out!
It’s hard to be sure without seeing your file. Are you able to share a link to your file, so we can take a closer look?
Thank you for answer me! Yes sure, here the link
Figma – 21 Sep 23
  • 4871 replies
Thanks, Laura!
  • September 22, 2023
Thank you so much! Now I understand where I was wrong!
You’ve been so helpful, really thank you!
