Hi, folks, I have bumped into this strange problem today: I can’t get the Fix Position check box to appear no matter how I try.
I have set the Scroll Behavior of the frame to be Vertical and made sure the frame is Clip Content with an overflow frame inside of it. But the Fix Position check-box still won’t appear!
And I’ve also tried opening the old file, in which, I had set Fix Position to the top bar, and when I select the top bar, the check-box still won’t appear. But in the Status bar on the left side, it clearly showed, the top bar is Fixed…
Is it just me? Or Figma made some changes to it?
