Component variant value dropdown option lists too narrow
Daniel_Ahlqvist
When choosing a variant of a component, the dropdowns could take up more space than they do. In many cases, the full variant values aren’t displayed. The attached screenshot shows a case when several options are not distinguishable, because their first halves are the same. I would suggest that you let the dropdown option lists adjust their width based on the option values instead of limited to the space the original input takes.
It would also be great if the list was sorted by name.
Skärmavbild 2021-06-11 kl. 08.30.40
Adam
  • 47 replies
  • November 30, 2021
Currently, the variant selection dropdown truncates at ~17 characters. If you have a moderately-lengthy variant naming structure, this becomes a major barrier to your workflow.
The dropdown should be extended from the right side of the page to at least the edge of the right-sidebar if not further.
Charles_Vass
After setting up a component with variants, if you’ve used long descriptions, you’ll see that the dropdown list opens partly off-screen so the text cannot be read.
Using longer descriptions is sometimes unavoidable and abbreviating them is not always ideal. It would be great if this could be adjusted in future updates.
Travis2
  • 77 replies
  • December 15, 2021
The variant name truncates after ten! It’s painful.
Michael_hatchwell
Screen Shot 2022-02-02 at 3.36.54 PM
Sometimes the names have to be a bit longer and the way the box open is usually weird and too small. Would love to have the possibility to either have a bigger box or the ability to detach it and move it somewhere else.
Monique2
  • 9 replies
  • February 15, 2022
I echo this sentiment
Spoony
  • February 18, 2022
Screenshot 2022-02-18 at 11.52.14
I think it would be great if with longer naming the tooltip in components variation would expand for me to see the whole name of the variant. Right now it crops out outside of the monitor which is not helpful much.
Zosia_Mroz
Hello, I also have problem with too narrow dropdown for variants. I cant’ see their names. And no - they variants aren’t use for icons. Those are just different states of certain component. Could Figma please do anything with narrow dropdown?
Baptiste_Deroche
Yeah, I hope this going to be fixed soon. Very frustrating behaviour 😭
Dave_Ackerman
Wish I could update this thousands of times – this is the biggest gripe I have with Figma at the moment. They designed all of their panels for a fixed-width, which just isn’t how design tools should work.
Alan_Gornick
This one is painful. Particularly because there is plenty of room for the names to display. It’s just got an arbitrary limit placed on the width for some reason.
Alan_Gornick
Agreed. It would be great to be able to widen the right panel, the same way the left panel can be widened.
Cody_R
  • September 7, 2022
Yep this is killing me.
NielsW
  • October 27, 2022
New user here. I’m having the same issue.
At least give us the ability to discover the full text behind the truncated options. A tooltip showing the full text would be one way. Expanding the width of the tooltip would be another. I.d.k. but at least do something.
Dora_Tang
  • October 28, 2022
Also agree - would be great to see this updated.
Teppo_Kotirinta1
How is this still not fixed? There’s whole screen width of space to the left of this floating dropdown. But instead of left, it tries to extend to the right, clashes with screen edge, and truncates? This bug/feature is hilariously stupid, annoying and super simple to fix. 🙂
Vova_Strashkov
Yep! This is still a thing, @Figma_Team please, fix this! 🙏
Just make a dropdown wider 🙏 please please pretty please!
If you feel adventurous – add a content “crawl” on hover for each item (see apple music for example)
Giblette_Ethan_M
Adding another voice… I’d like to be able to use more descriptive variant names but the menu is just too narrow!
Help, @Figma_Team!
Shamis_Amit
Odd and frustrating that this is not fixed yet, especially as this topic has been open for over a year. @Figma_Team please please please fix this.
Luno15
  • December 20, 2022
Would really appreciate this being fixed too.
Andreas_Hofmann
While working on Dynamic Width (Prio 1)
Please also add a Tooltip on hover of truncated Drop Down Elements to read the full text that can be maintained as Component Variant Name. (Prio 2)
Nanna
  • January 19, 2023
I add my vote to the many.
CC_Brightside
Upvote - have the same problem. Would be nice if there was a tooltip on hover, even better if the dropdown could be expanded horizontally, or if it fit the width of the longest name (could be right aligned).
Erika_Tolentino
I’m not sure if this is the same issue as described here… I can’t even see my options
My entire design org has this issue when trying to access a text component with various options. @Figma_Support is there ANY fix to this? Seems like basic stuff.
Clare
  • 15 replies
  • March 21, 2023
Please fix this @Figma_Team it doesn’t make sense to have variant names limited to 1 - 2 words!
