Can I mark a component as "added from my plugin whin these parameters" in components data and expose these parameters to project viewers?
  • September 19, 2022
  • 7 replies
  • 423 views
shenpengfei
I new to figma plugins, and I want to make a component plugin both for designer and developers, designer can chose parameters in figma plugin to generate a component, developer can get those parameters as viewer of this figma project, and use them directly in code project with the library I provided.
Is this possible with plugin API? or how can I do this in other ways?
shenpengfei
  • 6 replies
  • September 20, 2022
I found setPluginData method in plugin api docs, but how can I expose those data to viewers?
  • 4870 replies
Viewers cannot run plugins/widgets at this time.
Figma Help Center
shenpengfei
  • 6 replies
I knew, but can I serialize my parameters to string and store them to somewhere like component description or something similar to let viewers copy them?
shenpengfei
  • 6 replies
Maybe a redundant group and use it name to store them?
  • 4707 replies
Sure, both of these approaches would work fine.
  • 4870 replies
Yes, you can write your parameters in the component description. But editors can remove/change it.
figma.com
shenpengfei
  • 6 replies
  • September 21, 2022
Thanks, I’ll try this first.
