Jun 16, 2023 12:23 PM UTC
Auto Layout Bug?!
Hi everyone
I ran into an auto layout “problem” that makes me doubt what is the expected behaviour.
I could swear by that having the following settings resulted in an auto layout hugging the fixed item and the text adapting to the width of the fixed item. Instead the text just runs as wide as it can and the auto-layout adjusts itself after it. The only fix is setting the auto layout to fixed and then adjusting the fixed item to match the size.
Auto layout
Width: hug
Height: hug
Item A Image
Width: fixed
Height: fixed
Item B Text
Width: Fill
Height: Hug
Shukri
Jun 16, 2023 12:58 PM UTC
It is not a bug, but expected behaviour.
The parent frame is set to hug, and you assume the width it “hugs” is the fixed width image, but it hugs everything inside, and because your text is set to Fill, the text will take its entire length as there is nothing constraining it, and therefore, the parent frame that hugs takes on the width of the text item.
I hope that makes sense.
Istvan1Author
Jun 16, 2023 1:21 PM UTC
@Shukri This definitely is a bug or the least a changed pattern as components set up months ago are literally breaking due to this.
@Figma_Support This is a pretty big issue cause now we have to start worrying about previous client work and future updates. There was no update auto layout dialog. Just things breaking. I have submitted a report on this (via an organisation account, this was accidentally posted from my private one). Thank you in advance.
Erik18
Jun 19, 2023 9:38 AM UTC
Can confirm this is an issue for me as well. Usually the system would indicate that the layers or the parent changed settings from hug to fixed – and it doesn’t anymore. Having all layers with fill would automatically make the parent fixed before, for instance.
Wolf_Hadson
Jun 19, 2023 6:58 PM UTC
Item B: text is set to fill? Why, it should be set to fixed because auto layout of both is set to width hug, make sure either the auto layout or the text is set to a fixed value.
The issue can be found as the following:
Autolayout:
width: hug;
height: hug;
Item A: width:fixed;
height:fixed;
Item B: width:fill;
Height:hug
autolayout width & Item b width are not set to limit any width.
Limit either one of them you want and problem solved.
Hope this helps, good luck!
Christoph_Ono
Jun 21, 2023 7:37 AM UTC
Also an issue for me, and this is definitely changed behavior with a recent software update. Not great, please revert/fix, dear Figma team.
Istvan1Author
Jun 29, 2023 9:01 AM UTC
Finding broken autolayouts in random places all over our projects. @Figma_Support surely others have reported this issue.
Zoltan_Szalay
Jun 29, 2023 1:03 PM UTC
I noticed this change too, I also think this is a bug, and an issue for me.
Maybe this should be posted elsewhere, not in the “Ask the community”
Istvan1Author
Jul 3, 2023 7:50 AM UTC
@Zoltan_Szalay Nice to be confirmed that this is indeed a bug. Was second guessing myself a lot.
I opened an official ticket with Figma but they said they haven’t changed anything and argued for an incorrectly set up document and auto-layout. They were friendly and eager to help but I am not sure they understood the problem.
Note that this is not an issue when the text is wrapped into another auto-layout. That is often the case when designing a card but if you only have a single text box and image it is an overkill.
Arnaud4
Jul 10, 2023 1:16 PM UTC
Hi everyone,
Since the auto layout update, the top and left padding of all components of the Ant Design System for Figma UI Kit have disappeared. I have tested with different version of the UI kit, the bug appears each time. Has anyone else had the same bad surprise?
Thank you in advance for your help.
@Figma_Support !
Istvan1Author
Jul 17, 2023 12:39 PM UTC
I was in touch with Figma over the last weeks and I can repport they have fixed this issue.
