Add constraints to shapes inside union
Joakim_Strandell
Is there a way in Figma to add constraints to shapes inside a union. For example I need to create a modal window with an arrow that keeps it position on resize. Or is there an other way to do this?
  • 4710 replies
  • March 19, 2021
Yes, you need to wrap the union in a frame, then you will be able to assign constraints to elements inside of it. Constraints can only be set on objects inside frames, and groups/boolean operation objects are ignored, the objects inside of them will stick to the outer frame.
Jonathan_Schmitz
This bug still exists three years later. This is the (unfortunately annoying) workaround. Thank you!
Not sure why Figma’s interface would pretend to let us change constraints that are then ignored anyway 😦
  • 4710 replies
  • November 30, 2024
Not a bug. Groups work this way too, and you can not only change constraints but also colors and other properties, however the group itself doesn’t have any of such properties, it changes the objects inside.
