bart13
Jun 22, 2023 11:55 AM UTC
Variables: Color alias with alpha / opacity (rgba ideally)
hey there!
variables seems to be super nice but what i am missing is that if i make a colour alias to a specific collection - i can’t set the opacity separately (e.g. colour 50 with 20% opacity)
So basically i want the colouyr to be from another collection and i want to set the alpha seperatly (controlled as rgba - since i dont need it as opacity)
Example how we can fix this in token studio:
So what i want is that i can set blue/5 and then the opacity (which i dont want to capture in another colour variable)
Now its only possible if i break the link with gray/75 - and then i loose the reference to that colour
    Grigoriy2
    Aug 26, 2024 1:19 PM UTC
    It’s fucking necessary!
    pterisaur
    Aug 29, 2024 5:15 PM UTC
    Sooo needed. We’re now adding color themes to our library, and there’s no way to apply semi-transparent shades of the theme colors in our UI.
    mattaningram
    Aug 29, 2024 6:05 PM UTC
    This has been a feature request for years now. I have spoken to people at Figma about it, they are well aware it is a highly desired feature. I think they don’t want to do it because they think it will confuse users.
    Probably not gonna happen until a design tool comes along that doesn’t actively hold back its users.
    yu-mi
    Sep 2, 2024 3:28 PM UTC
    Can we get some confirmation whether this is actually happening? its been highly requested for so long, Figma are definitely aware of it yet releases seem to tackle everything BUT this.
    Just tell me whether its going to be done or not so I can modify my whole design system or pay for a external license for something like Tokens Studio.
    Andy33
    Sep 9, 2024 6:26 AM UTC
    Stumbling again upon this … so frustrating.
    rahend
    Sep 12, 2024 5:20 PM UTC
    Hey Figma,
    I wanted to share an idea that could make managing colors in Figma a bit easier. Right now, each color variable handles both the hex value and opacity together. What if we could separate them into two variables—one for color and one for opacity?
    Why?
    • Cleaner Palettes: You’d have a pure color palette without the opacity mixed in, and a separate set of opacity variables. This keeps your color palette simple and organized.
    • Easier Alpha Combinations: Want to create a color with different opacities? Just mix the color variable with an opacity variable, no need to manually create new color versions with alpha values.
    • Less Redundancy: By separating these, you avoid duplicating colors just to achieve different opacities, making it easier to maintain and update.
    This separation could make our design workflows more flexible and efficient. What do you think? Would this be useful for you too?
    Looking forward to hearing your thoughts!
    Trevor_Dupp
    Sep 23, 2024 8:27 PM UTC
    Hello Figma! - Its slightly disheartening to see this suggestion languishing since June 23. 😦
    The option to separate out alpha variables will open up a lot of potential. For example I want to create a Global Shadow style pack that I can utilize in builds that will allow you to adjust the color of the shadows using variables.
    To make nice shadows it requires utilizing many layers, it would be great to change one variable to apply to this shadow style to change all 5 Drop Shadow layers will maintaining their set opacities
    Dmitry_Boremsky
    Oct 1, 2024 10:37 PM UTC
    +1 Yes, please! Great idea, very powerful)!
    Mea
    Oct 8, 2024 2:17 PM UTC
    +100 Please work to add this functionality as you currently have to either a) Create a NEW variable that is not an alias; or b) detach the variable completely, which totally defeats the purpose of using the variable. Both options work against the usability of variable-based design system.
    Jeremy_Knudsen
    Oct 11, 2024 3:09 PM UTC
    I am continually running into this problem!! What you can easily do in code (CSS) is not able to be done in Figma, and it really is an oversight—a huge disconnect for what is needed in a design-to-code tool. Figma forces me to either detach the variable alias so that I can supply an opacity value to the variable color (which then makes a hard-coded hex color that no longer connected to the variable alias); or I have to create more tokens that are completely unnecessary in code. Please address this. 🥺🙏 I run up against this so many times that it really does feel like a bug in the Figma Variables feature.
