JosephxBrick
Oct 21, 2021 5:33 PM UTC
Turning off "snap to pixel grid" should turn snapping off!
Hi!
Turning off “snap to pixel grid” in a Figma Design file no longer changes snapping behavior when dragging frames around.
Whether this feature is turned on or off, a dragged frame still snaps to each pixel, no matter how zoomed-in. Note that some other objects (e.g., vector objects) still respect this setting. It’s just an issue with frames, components, and component instances. Note that If I group the frame, I then can drag the group to any sub-pixel location.
I’ve restarted my machine, restarted Figma, checked for updates, reloaded tabs, tried it in other design files. Tried it in the client, in Chrome, and in Safari. Same problem.
Can anyone else replicate this?
Carlos_Aguilar
Nov 7, 2024 3:16 PM UTC
Just learned about this when trying to align a logo that has a M and C and uses the C as base, when we need the M. So just keeping the request active to see if we get a solution 😉
Lorenzo2
Nov 13, 2024 4:15 PM UTC
Why did we get an app-wide update to UI sooner than a 3 years old fix?
deb2
Dec 18, 2024 7:44 PM UTC
Please fix this. Its entirely breaking my workflow for small reusable elements on prototype of a vector-based map. There’s no reason these elements need to be fixed to the pixel grid.
Liam_Salas
Dec 19, 2024 4:01 PM UTC
Figma please fix this. It’s extremely disruptive to workflow.
Tom_Auger2
Mar 14, 2025 4:41 PM UTC
I don’t know whether I’ve already posted my +1 - I probably have, but this should have been fixed ages ago.
The image below shows a frame nested inside another frame. The outer frame’s dimensions were set by a Distribute operation, thus it’s not on the pixel grid. The inner frame was created after this process and so I need to snap to object/geometry, NOT the pixel grid. Pixel grid is OFF and yet the corner handles snap to the grid when they absolutely should not.
Snap to Pixel Grid should be universal with no exceptions. I can’t think of a single use case where this might be the desired behaviour.
Figma, please address this bug ASAP, and please make it retroactive in UI V2 (because UI V3...)
johanfjr.com
Mar 31, 2025 10:40 PM UTC
About 3 years later, even UI 3 won’t fix this. 😂
What a dumb product owner and QA.
Leon_Wilson
Apr 5, 2025 11:12 PM UTC
BUMP - please have option like in every other program … Snap to grid
PleaseDisablePixelSnapping
Apr 23, 2025 3:45 AM UTC
Dear Figma team,
Please fix this. Not being able to disable this necessitates the use of another design program for small icons.
deb2
Jun 17, 2025 5:08 AM UTC
OlumideGabriel
Jun 28, 2025 9:29 AM UTC
It’s so annoying, but one way to play around this is to use a canvas with a higher pixel.
