Rnche_work
Jul 24, 2024 6:04 PM UTC
Stop automatically changing resizing parameters
I spend a lot of time undoing the automatic auto layout adjustments that Figma applies in order to maintain the existing layout structure. This is frustrating because I understand how all the resizing parameters work, and I only change the ones I want to change. But in an attempt to help me and retain the current layout, the UI changes parameters that were previously the way I wanted them. So while auto layout still saves me time, it also wastes my time by putting me in a position where I have to go through, layer by layer, undoing the auto-adjustments. (Usually changing a layer’s width or height from “fixed” back to “fill” or “hug”.)
I understand some users may actually like this, and it’s hard to please everyone. I would be more than grateful for an option that allows me to disable this automatic behavior.
Joe12
Jul 25, 2024 1:54 PM UTC
Having the exact same problem and its wasting my teams time!
I see no logical reason for this update and Figma from other comments cannot seem unable internally to decide themselves if its intentional or a bug!
Jul 25, 2024 3:54 PM UTC
Hey @Rnche_work, thanks for the feedback and apologies for the trouble this has caused!
We’ll pass this feedback onto the team as they continue to reevaluate the recent changes.
Jul 25, 2024 3:58 PM UTC
Hey @Joe12, thanks for the feedback and sorry for the confusion!
To be transparent, it is both. This originally was an intentional change. But as stated in the topic thread you linked, given the recent feedback from users, our team is re-thinking the recent changes, which is why we are now referring to it as a bug, until we can fix.
We appreciate your patience and understanding as we work through how to get things working as users expect they should.
Rnche_work
Jul 25, 2024 6:14 PM UTC
Thank you @dvaliao 🙌 You are appreciated. I know it’s hard to keep us all happy!
Brian_Saunders
Jul 26, 2024 10:46 AM UTC
100% agree with this—when it works it’s great, but most of the time it doesn’t do what I want it to do.
AntoineP
Oct 14, 2024 12:59 PM UTC
Not the same issue but a related one: I’d like to be able to disable the auto-setting of parameters when hitting CMD+A. Especially the auto “Fill container” applied by Figma that can mess with child components (very nasty with a fixed aspect ratio lock hack).
Antoine Pittiloni
Jan 16, 2025 9:57 AM UTC
I agree, undoing those parameters each time you apply auto layout is very time consuming and painfull when you need to work fast… is there anything we can do to desable this please ?
Best regards
Tom_Auger2
Mar 7, 2025 2:43 PM UTC
Figma, this is unacceptable. If the height is set to Fixed and the user switches autolayout direction, there is no reason to alter the fixed height value. This is a bug.
Naomi_Adkins
Apr 28, 2025 4:59 PM UTC
Is there any fix on the way for this? It’s incredibly frustrating to define fixed values and then have them all removed as soon as you add auto-layout. The video from Tom above shows exactly the problem.
Naomi_Adkins
Jul 28, 2025 11:29 AM UTC
Still waiting for a fix on this bug - it’s so annoying setting up a bunch of fixed width components, then having all the values removed if you try and use auto-layout (even just to arrange them in a design system!) at a later point 😖
