evgenypyvovarov
May 18, 2023 5:58 PM UTC
Stop automatically adding FigmaAgent to Login Items
I don’t use Figma all the time, I don’t want it to run anything on startup.
It’s frustrating to manually remove Figma from Login Items, since it automatically adds itself there again.
It would be nice to have at least an option to disable it in settings, or even better - remove that functionality at all, since it’s not user friendly. I want control over what and when the apps do at my workstation.
P.S. If it’s needed for updates check - I’m more than okay to update on app start
Pinned Reply By djv
Hey @Josh47, sorry for the frustration!
The FigmaAgent starts itself for font access & to allow you access to any Figma links without having to log in. If you don’t need either of those, you can force quit Activity Monitor, remove System Preferences > Users & Groups > Login Items
Then, delete ~/Library/Application Support/Figma/FigmaAgent.app & /Applications/Figma.app/Contents/Library/FigmaAgent.app
If you’re still getting the FigmaAgent on restart then you might have a corrupt .plist file. To remove this, try running a Spotlight search and delete system preferences plist from User library > Preferences > com.apple.systempreferences.plist
The file path should look like this:
/Users/Username/Library/Preferences/com.apple.systempreferences.plist
You might also want to delete the login plist if you have it
/Users/Username/Library/Preferences/com.apple.loginitems.plist
Alternatively, you can click on Go in your systems toolbar > Go to folder > and type in the path name (keep in mind Username should be replaced with your own). Then, restart your computer. These files will come back as new (without any corruption) and you should be able to completely remove the FigmaAgent service from login items without any issues.
Please note that Figma will automatically reinstall the login item when you upgrade the Figma desktop app. The only existing, temporary solution would be to uninstall the desktop app and use the web browser.
Our team already has this logged as a feature request internally, but to be transparent, there are no immediate plans on the roadmap to implement.
Miles_Cloud
Mar 31, 2024 2:08 AM UTC
This is actual malware behaviour. I don’t care what the app needs to download. I want to be the one that controls when the app launches and when it updates.
Stop modifying my system without my permission, especially after I REMOVE IT from the list.
Apr 4, 2024 3:13 AM UTC
Yes, im getting this issue its extremely annoying
harry_xu
Apr 4, 2024 4:29 AM UTC
This very annoying for me too. Can an option be added for users to choose whether to enable?
Apr 8, 2024 7:29 PM UTC
Please stop this. I do not want your agent running as a login item.
Marjory
Apr 23, 2024 3:25 AM UTC
The Figma agent is still appearing. Figma owners, are you not reading this and understanding your users?
Apr 30, 2024 1:27 PM UTC
+1 here.
Have to remove this app and use web version.
As long as user can’t control what app modifies in system preferences - it should be marked as malware.
Also, I like the fairytales about ‘fonts loading’ 🙂
Spoiler for Figma’s developers: you still can load all you need on app’s start with blocking UI.
Nobody needs some ‘fonts’ when app is not even running.
May 1, 2024 10:08 PM UTC
Hey All,
We updated the marked solution with the most up to date information from the team.
Again, for visibility:
If you don’t need FigmaAgent, you can force quit Activity Monitor, remove System Preferences > Users & Groups > Login Items
If you’re still getting the FigmaAgent on restart then you might have corrupt .plist file.
Alternatively, you can click on Go in your systems toolbar >Go to folder > and type in the path name (keep in mind Username should be replaced with your own).
Then restart your computer. These files will come back as new (without any corruption) and you should be able to completely remove the FigmaAgent service from login items without any issues.
Dhiraj_Ingle1
Jun 24, 2024 4:33 AM UTC
Still an issue. Still super annoying. Please fix.
Arnaud5
Jun 24, 2024 8:49 AM UTC
(and no we do NOT want to make annoying steps to delete files or whatever, just give us an opt-out option)
Jul 13, 2024 3:52 PM UTC
This is just infuriating. If I remove the login item (which apple allows you to do in user preferences), Figma should honor that request, even on subsequent updates. It’s not that hard or complicated. Doing this wouldn’t change the default behavior at all for users who want the login item, and it would drastically improve the experience for users who don’t.
