Shelene_Lee
Feb 24, 2021 6:01 PM UTC
Show Font Weight in Inspect panel
When inspecting the following component, I can click on the font to see the font weight and style in the inspect panel. When my dev clicks on the same item, he does not have all the CSS information that I have in the inspect panel, specifically he is missing font weight and font style. He does not have the ability to see the different font weights, which is unacceptable. Is there some way to fix this?
Component with my inspect panel:
Screen Shot 2021-02-24 at 10.12.33 AM
My (designer) Inspect panel:
Developer Inspect Panel:
✏️ Note from the moderator
There is a way to see the actual font weight, but it’s hidden and inconvenient: Show Font Weight in Inspect panel - #5 by Gleb
Anni_V
Nov 8, 2022 8:12 AM UTC
Bump. This has been a pain in our handover process for a while and only now I’ve understood the root of the cause. This needs to be fixed.
Johannes_van_Mierlo
Nov 22, 2022 1:30 PM UTC
Same issue here! 😕
dennsi
Nov 22, 2022 4:26 PM UTC
Bump… please fix this Figma or give us the ability to declare font-weight overrides for the Inspect Panel
Soledad_Mari2
Dec 6, 2022 8:05 PM UTC
+1
this issue is causing handoff delays and misreporting of bugs in our team. is the solution in the works? it’s been consistently reported for almost two years now…
Julie_Turgeon
Jan 3, 2023 5:19 PM UTC
Same issue here.
Maxime10
Jan 10, 2023 2:07 PM UTC
Please fix this. My devs will kill me soon.
Mar 3, 2023 1:23 AM UTC
Just sharing another instance of this bug. Brandon Grotesque (Adobe Typekit font) is being used at the weights 400, 500, and 700 in this project, but Figma displays the weights as 390, 420, and 450 respectively. I’m really not sure what the deal is here, but this bug has thrown a wrench into pretty much every design/dev handoff for every project I’ve worked on in the last few years. Our designers specify elsewhere what the weights need to be for a project, but inspecting other components requires us to translate the erroneous values in your head to the real weights.
In screenshot, the selected text box should show 700 as the weight.
Sharon_Taylor
Mar 22, 2023 1:31 PM UTC
We just had the same issue, our devs noticed that the weight was shown as 400 in figma when it should be 700.
Apr 20, 2023 4:05 PM UTC
Any fix for the font style showing incorrectly in inspect? We updated font styles and the inspect panel is showing the old styles. Super obnoxious as the old style showing is different than the new styles so stuff is being built incorrectly on their side.
Jun 30, 2023 4:19 AM UTC
Hi, I’m currently facing the same problem as OP, especially after the introduction of Dev mode.
This is really frustrating to deal with as it slows down development and creating style sheets that specify every detail of each text style is time-consuming 🤬 😡 😡 😡
