ChiSenires
Jan 8, 2024 2:47 AM UTC
Setting variables for delay time?
Would it be possible to attach the delay value to a variable?
I was initially working on a prototype flow where it’s possible that the system either moves to another screen quickly, or it takes some time (depending on system processes). I wanted to simulate that.
I also noticed this idea (Use variables for transition timing) which is kind of related, but mine is looking into a different value. Maybe our ideas could be merged together for just allowing variables in prototyping values 😀
Jan 9, 2024 6:55 AM UTC
Hi there,
Thank you for providing feedback! I will share this with our internal team. Your input is highly valued, and we will take it into consideration for future enhancements.
Toku
Ernest_Fowler
Apr 23, 2024 2:01 PM UTC
Did you find a temporary solution? I’m also facing the same situation.
ChiSenires
Jul 12, 2024 1:53 PM UTC
@Ernest_Fowler What I ended up doing for this was having a variable that determines which flow the user would have to go into, and also including a starter screen in the prototype to somehow “configure” the variables. So if I wanted to demonstrate Flow B instead of Flow A, I would have a toggle that could be changed at the start of the prototype. Then, during the fork, that would just be a conditional statement based on the value of the variable (if A then go to Flow A, else go to Flow B).
Chi
Gomez_de_Llarena_Figueredo_Car
Nov 7, 2024 6:14 PM UTC
+1 It’s an inefficient use of time to have to type a number on every single transition you are trying to tweak a bit… 🙏
arda0
Aug 26, 2025 12:05 AM UTC
Hi there,
Toku
So, is there any updates? I’m still waiting for this feature.
sorarize
Oct 24, 2025 4:36 AM UTC
I’m waiting for this feature, too. I hope I can use variables anywhere in the app.
