Aalok_Trivedi
Feb 9, 2021 11:40 PM UTC
Scale as a property
Scale is one of my most used properties when designing interactions and states. It would be great if we had true ‘scale’ as a property.
No, I’m not talking about the scale tool. That’s fake scale that affects the width/height of elements.
I want the ability to enter something like ‘1.5’ and change the scale of an element, respectively.
Julien.L
Aug 1, 2023 1:14 PM UTC
Those familiar with the Principle for Mac application will be familiar with the coveted Scale feature. It’s as simple as that 😉
But what I like about Figma, and what Principle for Mac doesn’t have, is that you can scale by changing the width or height, which automatically calculates the scale value.
Alina_Trussova
Sep 7, 2023 8:06 PM UTC
Has anybody fixed this? I am having similar issue. Creating different sizes for each icon with a variant is not an option for me due to extensive icon library.
Bianca_Copello-Schoen
Sep 19, 2023 3:58 PM UTC
I was able to fix this using these steps:
  1. Select all the individual strokes that make up my icon
  2. Do a union selection to convert them into one single layer/object
  3. Right click or Shift + Cmd + O to outline the strokes
  4. Set the layer to scale within the component frame
After that, any instances of that icon component scaled correctly by changing the stroke width as well.
mtartaglia
Oct 3, 2023 1:10 AM UTC
It would also be awesome if the scaled amount was visible in Dev Mode! My team has a need to have certain UI components that have a designated size be “scaled larger” in some designs/use cases, and being able to have that scale change be easy to see for developers would be amazing.
Kristaps_Stikuts
Oct 6, 2023 7:56 AM UTC
Currently seems that stroke, text size and effects inside nested components are resetting to their default state defined in the master component.
Even after recent Figma bugfix that fixed issues with absolute position on scaled components in auto-layout, this issue still persists.
davlad
Oct 7, 2023 2:27 AM UTC
your comments are always helpful.
I can’t imagine how you’ve sorted this out but thanks!
Julien.L
Oct 12, 2023 12:23 PM UTC
I agree 100% with this suggestion. I might add the inking point for scaling so it doesn’t have to be done from the center.
ignaciogiri
Oct 26, 2023 4:33 PM UTC
I have many occasions where I could use this feature.
Kristaps_Stikuts
Oct 27, 2023 10:35 AM UTC
bump, please.
Nate_G
Power Member
Oct 27, 2023 3:45 PM UTC
@Alina_Trussova I put together this example file to a similar question, on how one could address button+ icon scaling, swapping and coloring. Hope it helps 👍
Nate G
