Aalok_Trivedi
Feb 9, 2021 11:40 PM UTC
Scale as a property
Scale is one of my most used properties when designing interactions and states. It would be great if we had true ‘scale’ as a property.
No, I’m not talking about the scale tool. That’s fake scale that affects the width/height of elements.
I want the ability to enter something like ‘1.5’ and change the scale of an element, respectively.
IraX
Power Member
Nov 16, 2022 10:25 PM UTC
This would be SO useful. Especially for prototyping any zoom/scale UI.
Ryder
Nov 25, 2022 6:21 PM UTC
Warning: noob comments below 🙂
Yes. This.
Scaling seems to occur from the TL corner by default.
As a noob, I may be misusing the term, but I am truing to make a variant that has been enlarged using the handles… and animating between (effectively a scale), and no matter what I try, the animation is anchored to the TL of the default variant.
I hope there is a way… (sort of an “action center”???)
Ryder
Nov 25, 2022 6:23 PM UTC
What needs to be rethought is the entire notion of properties.
They should not exist (this will confuse so many people)…
Everything should be a behavior. There are monumentally good reasons for this.
jorgefernandess
Jan 16, 2023 1:29 PM UTC
You just need to add a hug content to each individual icon size and that will prevent the icon from being resized through the master component.
DNLBTLR
Feb 9, 2023 10:07 AM UTC
Hey Ben! i’m struggling with exactly the same issue - Read through all these comments here but doesnt seem like it got fixed…did you figure it out somewhere else?
DNLBTLR
Feb 9, 2023 10:56 AM UTC
Did anyone figure out a fix for this? Here is a screenshot from the master icon library file i’m using where you can see the layers. If I should adapt the master icons, please let me know what I should do.
Aalok_Trivedi
Jun 16, 2023 12:04 AM UTC
replying so this doesn’t close
jasonhibbs-cm
Jun 19, 2023 11:27 AM UTC
+1, I have icons at 24px with an intent to scale uniformly, but where I’ve used stroke inside boolean operations (to preserve editability), these aren’t scaling while in a swapped and nested instance.
Hopefully it’s clear in these images; the icon is scaled to 32px using the scale tool, but when swapped, the stroke weights are not scaled.
jasonhibbs-cm
Jun 19, 2023 11:30 AM UTC
Yes, I need this (or similar) or I’ll be unnecessarily duplicating (or flattening) an icon library for the sake of strokes that don’t scale.
I use booleans to preserve underlying strokes but these don’t scale when in swapped and nested instances.
Preston_Lewis
Jun 27, 2023 1:57 PM UTC
This is a serious issue that seems to be re-introduced with recent updates. I believe there is something happening when there are nested variants inside of a new master component. See video:
