Scale as a property
  • February 9, 2021
  • 95 replies
  • 7214 views
Aalok_Trivedi
Scale is one of my most used properties when designing interactions and states. It would be great if we had true ‘scale’ as a property.
No, I’m not talking about the scale tool. That’s fake scale that affects the width/height of elements.
I want the ability to enter something like ‘1.5’ and change the scale of an element, respectively.
  • February 10, 2021
So what would you scale with this scale if not width/height? Only stroke thickness?
Aalok_Trivedi
@Gleb No it will affect everything, just like current the scale tool, but I want it to behave like a true scale property. The current scale tool just adjusts the actual values to match that scale value you drag it to. My idea is actual scale property I can control., but doesn’t affect the layout.
In actual dev, scale doesn’t actually physically change the computed width and height of an element; you’re just changing it visually.
I know it might be a little more tricky, Tech/UX-wise, but I think this way could work. Here is a simple example of what I’m envisioning:
Shared with CloudApp
  • February 10, 2021
So it basically works like Scale tool but for inner contents of the frame? Why not use Scale tool then? And why can this be useful in Figma?
Aalok_Trivedi
No it’s It’s different. Also I can’t control the percentage of the scale. I have to rely on the property width and calculate it myself, which is frustrating. The current scale tool is just a glorified resizing tool
  • February 10, 2021
What if you could control the percentage of scale tool? (Actually a plugin called skale already allows you to do that.) Will that solve your problem?
Aalok_Trivedi
No not really, because it will still change the actual dimensions of the element, which will potentially affect the rest of the layout behavior, especially if it’s in an autolayout (ex: I have a list of items and want an item to change scale on hover or click).
  • February 10, 2021
As a workaround you can simply put your list item in a frame and scale it, leaving the frame the same size, like you showed above.
Aalok_Trivedi
I’m aware, but this is a feature request so I don’t have to rely on countless workarounds that add more unnecessary complexity. Thanks though.
Dario_Stefanutto
Hello beautiful people.
Basically I have a component instance which I resized inside another component. When I try to swap the nested component, Figma doesn’t keep the scaling and brings it back to 100% of its size. This happens only with nested components.
Is this a bug? Any idea of how to fix this?
Bruno_Figueiredo
I think this is a limitation, but people have already started posting about it on several slack channels and here too.
Aalok_Trivedi
Yes! This is why we need scale as an actual property control. the current Scale tool isn’t actually a true scale. Scale as a property
@Gleb this is a perfect use-case for it.
Dario_Stefanutto
Yeah, I use a plug-in called “scale”. It’s so basic I wonder why it’s not a native feature.
David3
  • February 22, 2021
+1. We want this. IMO feels like a buggy implementation of “scaling”
Ben_Greenberg
I’m hoping I can find a resolution to this as I’ve been confused about the product behaviour since variants launched last year.
Essentially, I have icon library for which each are defined as a component. They follow a standard naming scheme (starting with icon/) so that icon instance can easily be swapped using the Swap Instance menu option. They also follow a standard sizing of 24x24 px.
In a common pattern, I then need to create a standardised Button component. I create this component and add an icon instance inside the Button component. Then, to extend this library, I create a new variant of the Button component which is the “small” variant. For this I need to make everything smaller including the icon, so I use the scale tool to reduce the icon instance to 12x12 (which also decreases the line weight). This scaling behaviour is commonly done by browsers when resizing SVGs.
When I create an instance of either the “normal” or “small” button, everything seems fine. However as soon as I want to swap the icon instance in the “small” button instance, the scaling of the icon that is swapped in doesn’t match. It is correctly sized at 12x12 however the line weight is not scaled down as expected.
I have created a step by step reproduction of the issue in this public Figma file, and I include a brief screenshot of the Figma file below for reference.
Figma – 20 Nov 20
If anyone can help me with this highly confusing behaviour I’ll be eternally grateful. I simply don’t understand how people can work with icon libraries and the variants feature when scaling of icons isn’t managed consistently by Figma components.
chudoloo
  • February 27, 2021
From personal experience, the solution to this problem (not just for Figma), is to outline strokes of icons when they’re part of a library and delivered as an asset (SVG).
It’s good to keep a separate file of the original icons with stroke paths so you have a “source” that can be edited and worked on, but once the icons are ready to be added to a Figma library or exported as SVGs, all strokes should be conveted to outlines. This makes changing the fill color easier not only in Figma but with CSS (for SVGs). And on top of that, you avoid the problem you’re dealing with altogether since you’re only dealing with shapes and fills.
Ben_Greenberg
Thanks for your response! This seems a little strange to me - I’ve inherited this from previous designers who already had the icons in a separate Figma file as a library. Perhaps I should go investigate that source a little bit more.
I also found this on the forum: (Issue) Keep the scaling of a nested component when swapping it
It seems that the issue of nested instances not retaining their scale is an issue that doesn’t just affect things like icons.
Lio
  • March 1, 2021
100%
Lio
  • March 1, 2021
BorojiDesignInc
Scale in and scale out animation preset
It would also be nice if we have 2 preset options of scaling in and out from the center added to the presets. It would save me a lot of time animating overlays 😄
Thank you
Gavin
  • Active Member
  • March 1, 2021
I know what @Aalok_Trivedi is saying. It’s the ability to abstract the idea of scale from components/objects so that you can scale them in a non-destructive manner. This means relationships can be built between different components. For example, a header could be an instance of a text component and set at a specific scale. Then an instance of that header could do the same. In theory, it’s possible to do this using the scale tool, but it’s not intuitive to the way that scale is perceived as a characteristic by designers. The question is how would this be achieved through UI that doesn’t add issues or increase unnecessary complexity. I’d like scale as a property not just for frames but for properties as well like border thickness.
Aalok_Trivedi
@Gavin Yes, exactly. I honestly don’t think it would complicate things, but I’m sure there would be a few wrinkles to think about. I was envisioning a literal scale input that would scale everything inside the frame (stroke, corners, text, etc…), exactly how it would work in development. Although they are not a design tools, Principle and Origami have this for prototyping and it works well.
As I’ve said before, the current scale tool isn’t really a true scale tool. It just uses a scale to calculate computed dimensions; which you’ve mentioned is destructive and frustrating to control.
Gavin
  • Active Member
  • March 1, 2021
Interestingly there is already a concept of a scale property underneath the hood, (see Figma Plugin API) but this only exists on instances I believe.
Jean-Marc_Lehwald
Guess I´m struggeling with the same issue.
Jean-Marc_Lehwald
There are so many plugins called scale, skale oder scale whatever, can you let us know which one it is? <3
Dario_Stefanutto
This one!
