Namson
Oct 28, 2021 10:42 AM UTC
"Return to instance" shortcut for Figma links
Hi!
My team exclusively uses Figma as the source-of-truth for implementation across various verticals: product, design engineering… We heavily rely on deeplinks to cross-reference other relevant files, flows, screens or resources to make the hand-off files easier to navigate for engineers.
Our problem is, after clicking a link that leads to another frame in the same file, there’s no way to go back to the previous page: People need to manually navigate the file hierarchy and sections organisation to retrace their steps. Easy when you’re the person who came up with all these flows and know the file org by heart, but hard for anyone else. 😅
A floating action similar to the “Return to instance” button we have when shortcutting to a master component would be ideal. A keyboard shortcut to do that would be good enough. Any thoughts here?
Patrick-Plaggenborg
Would be amazing to have a keyboard shortcut for ‘Return To Instance’.
Long term solution:
  • Add as macOS menu item. We would then be able to create our own shortcut for it
  • Add as official native Figma keyboard shortcut
Unfortunately this is not there yet. I did find a workaround that can speed up your workflow by quite a bit though!
Workaround:
(For this example it does require that your Figma application window is sized somewhat similar in every session)
  • Download BetterTouchTool (paid app)
  • Create a new keyboard shortcut for Figma
  • Set the Trigger shortcut to your liking
Then as the output:
  1. Save Current Mouse Position
  2. Move Cursor to new mouse position, based on Bottom Center of Active Window (move cursor to the location of the Return To Instance button)
  3. Left Click
  4. Restore Saved Mouse Position
Other possibilities
This tool works so well that you do not even see the mouse changing position. It really feels like a normal keyboard shortcut and it has saved me so much time.
  • Similarly I created a shortcut to quickly jump to follow/view profile of another designer in the same file.
  • Also BTT allows you to create or reconfigure keyboard shortcuts for menu entries that for some reason are ignored when setting them in the regular Keyboard Shortcuts settings in System Preferences.
Game changer for me, until Figma allows for more solid support and flexibility for custom keyboard shortcuts. Give it a try.
01 return to instance
My settings in BTT (make sure to adjust to settings that match your particular screen):
Rob_Corradi
Jul 7, 2022 5:37 PM UTC
I use links inside my Figma design files to help people get around and across Pages.
But for people who don’t know the file well, getting back can be tricky.
It would be very useful if Figma provided a “Return to source link” option for links that opened within the same Figma file, that worked in the same way as the existing “Return to instance” function does.
Click a link to go somewhere in the file, and then just click to get back.
Super-useful - and probably not hard to implement?
Nick_Zhurenko
Sep 7, 2022 3:50 PM UTC
You have a really cool feature - after click on “Go to Main Component” there is a bubble option on the bottom of the viewport “Return to instance”.
I use cross-linking system in the file. It could be good if user will see the similar button when he click on the link to the Frame in the same Figma file)
Dennis_N
Power Member
Sep 8, 2022 9:10 AM UTC
Nick_Zhurenko
Sep 8, 2022 9:24 AM UTC
Should I delete my idea and vote for that one? Or it’s not a problem to have 2 similar requests?
Dennis_N
Power Member
Sep 8, 2022 9:29 AM UTC
A moderator could decide to do so. I just wanted to “connect” both ideas so votes are not split up while we all are requesting the same 🙂
Btw: You inspired me to share a similar idea:
https://forum.figma.com/t/return-to-instance-option-across-files/29240
Dennis_N
Power Member
If you are working with local components where all the components and instances are within one file you have this neat “return to instance” snackbar at the bottom.
If you are using external libraries like I’m doing all the time, you don’t have this option.
I think it would be handy and more consistent if we could also have this feature across different files.
Yeah, not a big dealbreaker since you just need to change the tab but with lots of open tabs a nackbar would be even better.
I was inspired by this idea:
https://forum.figma.com/t/after-click-on-the-link-to-the-frame-and-move-viewport-to-the-frame-there-should-be-a-button-back/29190
Apr 7, 2023 4:36 PM UTC
Apr 7, 2023 4:44 PM UTC
Thanks for the feedback, @Namson!
We’ve merged it with similar feature requests from the past to hopefully better gauge interest from the community.
AkiF
Aug 10, 2023 2:51 PM UTC
@dvaliao Does the mean someone is working on a more elegant way to navigate between master components and instances — a completely different approach which could solve this an many more issues would be a back button/keyboard shortcut to navigate back – and forth.
